Which diagram below best representsthe shape ofthe rope when both puls
1 reply · 3K views
cmkc109
The diagram shows two pulses, each of length , traveling toward each other at equal speed in a rope
Which diagram below best represent sthe shape ofthe rope when both pulses are in region AB?
The answer is the last option, it will be a flat line
but this looks like constructive to me, meaning they should add up since they are the same when approaching...
greatly appreciated if someone can explain with a diagram ,thanks
And same as #73, i should don't know how to picture how these things work ...
Initially the two +ve peaks collide and you do indeed have constructive interference and a +ve peak twice the height BUT when that happens the two waves only overlap by λ/2 and they aren't entirely within the region AB.
The +ve peaks continue past each other until the +ve peak of one overlaps with the negative peak of the other and you get destructive interference and a flat line. At this point both waves are within AB. So flat line is the answer.
If you let the clock run further the waves keep going until the -ve part of one overlaps with the -ve part of the other. You get constructive interference again only this time a -ve peak twice the height forms. Again this happens when they overlap by λ/2 and they aren't entirely within the region AB.
