What Formula Should I Use for Calculating Vector Components in Physics?
  • Thread starter Thread starter katie_08
    Formula
To calculate vector components in physics, the key formulas involve breaking down vectors into their x and y components using trigonometric functions. For acceleration, the formula a = F/m can be used, where F is the force and m is the mass. Displacement can similarly be resolved into components using the sine and cosine functions based on the angle of the vector. Understanding that vectors have components is crucial for solving these problems effectively. Proper application of these principles will lead to accurate calculations of both acceleration and displacement components.
katie_08
I have a physics worksheet to do and i have all of the information for the problem, but i just can't figure out what formula to use. Right now we are working on force problems and the question says to find the x and y components of the acceleration. Then another question says to find the x and y components for the displacement. I am NOT asking for anything other than which possible formula to use for this problem. If i didn't write enough of the information, let me know and i will add it. Thank you if you can help me at all. It would be very much appreciated.
F=ma is a vector equation. Are you given an F?
yes, i was
katie_08 said:
yes, i was
Well, vectors have components. There you go!
