Uncovering the Missing Gluon: The Mystery of 8 Gluons in SU(3)
  • Context: Graduate
  • Thread starter Thread starter steven.noyce
    Gluon
The discussion centers on the existence of 8 gluons in Quantum Chromodynamics (QCD) and their representation in the context of the SU(3) gauge group. Participants clarify that while novices may initially perceive 9 gluons based on color charge combinations, the correct count is 8 due to the properties of Hermitian matrices and the adjoint representation. The gluons are represented by 3x3 matrices, with specific configurations leading to the exclusion of certain combinations. The conversation emphasizes the importance of understanding the mathematical framework behind gluon representation and the implications of QCD confinement.
  • Understanding of SU(3) gauge theory
  • Familiarity with Hermitian matrices and their properties
  • Knowledge of quantum chromodynamics (QCD)
  • Basic concepts of Lie groups and their representations
  • Study the adjoint representation of SU(3) in detail
  • Learn about the mathematical properties of Hermitian matrices
  • Explore the concept of QCD confinement and its implications
  • Investigate the structure of Lie groups and Cartan subalgebras
Physicists, particularly those specializing in particle physics, theoretical physicists, and students studying quantum field theory who seek to deepen their understanding of gluon dynamics and the mathematical framework of gauge theories.
steven.noyce
I know that it is a common question to wonder why there are only 8 gluons, so I am sorry for bringing it up again. I have been reading a lot lately about SU(3) and Hermitian Matrices with trace 0, and basically everything seems to make sense, that is except for one item. Despite seeing logic in all the mathematics, it seems that each of the 8 gluons should have a name, so a list of these names should be easily made. I would love to see such a list, but I do not see how one can eliminate a single name from the list of 9 gluons that is so simply conceived by any novice learning of color charge before learning that there are indeed only 8 gluons.
name?
Sorry that actually I don't quite understand your question.
But I would explain what I know and may help you.
First of all, the gauge fields is in the adjoint representation of gauge groups. Take the group to be SU(N), the number of generators is N^2 - 1, so that we have 8 gluons in QCD.
However, there is no need to give those gluons specific names.
First of all, in fact we have given those gluon fields an adjoint index, which allows us to manipulate them. Moreover, there is no calculation and no experiments that can directly observe the specific gluons due to the QCD confinement. Unlike the case of weak interaction, which we have the W and Z bosons, and unlike the case of EM interaction, which we have photon, we cannot observe the gluon degrees of freedom.
That's why if you take a look at the table of masses of gauge bosons, you would see there is a bound for photon, say mass of photon < 10^{-10} kg (I just write it as an example, not a true number in the literature.), but you would see the mass of gluons to be exactly zero.
Hope this helps you.
I think I know what you're getting at.
If X and Y are colors, then a gluon should exist that takes X and changes it to Y. Such a gluon would be an X/Y, for example, R/G. Since there are three choices of X and three for Y, there should be 9 gluons.
The counting argument works when X is not equal to Y. There are 6 such gluons:
R/G, R/B, G/R, G/B, B/R, B/G.
Gluons follow the adjoint representation of SU(3). In this representation, these 6 gluons are represented by 3x3 matrices with a single 1, either above or below the diagonal, like this:
\left(\begin{array}{ccc}<br /> 0&amp;1&amp;0\\0&amp;0&amp;0\\0&amp;0&amp;0\end{array}\right) = R/G
where the matrix entries are "R", "G", "B" instead of "1", "2", "3". Note that the above matrix converts the "G" ket: (0,1,0) into the "R" ket: (1,0,0) so it is called the R/G. It is at least possible that my notation is reversed from everybody else and this should be the G/R.
You'd think that there would also be gluons represented by a single 1, on the diagonal, but sadly this is not the case. Instead, the diagonal gluons look like:
\left(\begin{array}{ccc}<br /> +1&amp;0&amp;0\\0&amp;-1&amp;0\\0&amp;0&amp;0\end{array}\right) = R/R - G/G
\left(\begin{array}{ccc}<br /> 0&amp;0&amp;0\\0&amp;+1&amp;0\\0&amp;0&amp;-1\end{array}\right) = G/G - B/B
\left(\begin{array}{ccc}<br /> -1&amp;0&amp;0\\0&amp;0&amp;0\\0&amp;0&amp;+1\end{array}\right) = B/B - R/R
There are three of these, but first, no one of them is R/R, and second, they are not linearly independent; they sum to zero. And since they are not linearly independent, we leave one of them off. And for technical reasons, instead of taking the first two of the above, the custom is to take the first one, plus:
\left(\begin{array}{ccc}<br /> +1&amp;0&amp;0\\0&amp;+1&amp;0\\0&amp;0&amp;-2\end{array}\right) = R/R + G/G - 2 B/B
Thanks, guys, it is beginning to make more sense now.
CarlB, I was wondering how you chose three of the six diagonal gluons. Would there not also be
<br /> \left(\begin{array}{ccc}<br /> -1&amp;0&amp;0\\0&amp;+1&amp;0\\0&amp;0&amp;0\end{array}\right)<br />
<br /> \left(\begin{array}{ccc}<br /> 0&amp;0&amp;0\\0&amp;-1&amp;0\\0&amp;0&amp;+1\end{array}\right)<br />
and
<br /> \left(\begin{array}{ccc}<br /> +1&amp;0&amp;0\\0&amp;0&amp;0\\0&amp;0&amp;-1\end{array}\right)<br />
How did you chose three from the six? Is there not a difference between things such as R/R-G/G and G/G-R/R?
Also, I am super confused as to what the ¨technical reasons" would be for using that last matrix instead of two of the others.
Thanks for the help!
Yes! However, quantum mechanics always allows arbitrary complex phases to states. The action of the operator R/R - G/G on a state is the same as the action of the operator
\exp(i\theta)(R/R - G/G)
for any theta, except for that arbitrary complex phase.
It's really not that technical. I'll try explaining. However, I'm likely to get some terms wrong as I am just writing this from my memory and it's not a subject I care much about. (I work with Clifford algebra stuff rather than symmetry stuff.) Hopefully someone will step in and fix this.
When you analyze a Lie group, the first thing you do is to try to find a maximal Abelian subgroup. Which means it is as big as possible and all its elements commute with each other. This a Cartan subgroup, and in terms of a matrix representation, you can arrange for the Cartan subgroup elements to all be diagonal. For SU(3), these are the gluons that are confusing, R/R - G/G, etc.
Now there are an infinite number of ways of describing that Abelian subgroup. For the case of SU(3) it is 2-dimensional because, as mentioned before, the three objects (R/R-G/G), etc., all sum to zero so there really are only two. So you're going to have to pick two objects out to represent the subgroup with a "basis".
For a basis, one of the things you want is for them to be orthogonal. But (R/R - G/G) and (G/G - B/B) are not orthogonal. To make them orthogonal, you have to replace that second one by (G/G-B/B) - (B/B - R/R) = (R/R + G/G - 2B/B). To see this, you have to know what "orthogonal" means for the basis elements of the Cartan subalgebra.
I'm not sure if this is right, but the obvious way to define orthogonal is to take the trace of the product. This works, but I'm not sure if it's the right way of defining it.
Don't worry about thanking the people who help here. It's our way of either learning the material or trying to not forget it.
  • · Replies 27 ·
  • · Replies 27 ·
