Which number set does log(0) belong to?
  • Thread starter Thread starter Garlic
    Set
Log(0) is not defined in standard mathematics, and its limit approaches negative infinity as x approaches 0 from the positive side. It can be considered part of the Extended Real Numbers, but this classification is not universally accepted. The discussion also touches on the nature of number sets, including the complex numbers and quaternions, and how theoretical mathematicians may define arbitrary sets beyond conventional numbers. The concept of ordered fields is explored, noting that the complex numbers and extended reals do not qualify as ordered fields. Ultimately, log(0) remains undefined within the context of ordered fields.
Garlic
Hello everyone,
Which number set does log(0) belong to? Or does it belong to any number sets?
Mathematics news on Phys.org
Garlic said:
Hello everyone,
##\log(0)## is not defined.
The most you can say is that ##\displaystyle \lim_{x\rightarrow 0+} \log(x) = -\infty##.
You could say it belongs to the Extended Real Numbers, I guess.
Likes Garlic
Which then is part of the "extended real numbers".
Likes Garlic
Is this statement true: "Any number z is an element of the complex numbers set"
Are there any sets for numbers which aren't defined in the complex number set?
What happens when a theoretical mathematics researcher or a philosopher thinks outside the "normal numbers" box? Do they define an arbitrary set, or is there an outermost number set?
One example:
https://en.wikipedia.org/wiki/Quaternion
Garlic said:
Is this an example of how people can define arbitrary sets, or every number z is an element of the Hamilton set H?
You certainly can define your set of "numbers" as you like (if a definition is useful, or maybe more important from a mathematical point of view, interesting, is another matter).
For example, numbers not related to the quaternions are the p-adic numbers.
Likes Garlic
Thank you for your explanation :smile:
Some of the examples you've been discussing are not ordered fields. For example, the complex numbers are not an ordered field, because there isn't an ordering defined on them. The extended reals aren't an ordered field because they aren't a field.
But if you restrict yourself to ordered fields, then the surreal numbers are in some sense the "outermost." ("In some sense" means that it depends on what set-theoretical foundations you take.) The surreals are a proper class, not a set.
Re your original question, I would guess that it's possible to prove that in an ordered field, log(0) is undefined.
Likes Garlic
  • · Replies 44 ·
  • · Replies 17 ·
