Why are these capacitor voltages opposite polarity?
9 replies · 3K views
kostoglotov
imgur link: http://i.imgur.com/JETj0Cq.png
[tex]V_L = L\frac{dI_1}{dt}[/tex]
[tex]V_L + V_1 + V_2 + V_{R1} = 0[/tex]
[/B]
Just using basic KVL, shouldn't [itex]V_L = -V_2 - V_1 - V_{R1}[/itex] and so therefore we should get
[tex]\frac{dI_1}{dt} = \frac{-V_2 - V_1 - V_{R1}}{L}[/tex] and not
[tex]\frac{dI_1}{dt} = \frac{V_2 - V_1 - V_{R1}}{L}[/tex]
which is what the question is asking us to find...it would appear then that the capacitors have opposing polarities...why?
I think you are right, the terms on the right hand side in (4) should all have negative signs.
It entirely depends on how you define the capacitor voltages. My guess, they (being the book authors) defined the voltages in a different way and didn't actually write it down through an oversight.
No, this is not from a textbook, this is from an assignment.
I1 and I3 are going in the same direction around the loop that we use in KVL though, no matter how you set it up.
I've only followed the current directions indicated. I haven't chosen my own directions independent of the problem.
same thing, whoever defined the assignment did a bad job
does not change what I said... saying they have V1 backwards without defining V1 is useless, same goes for V2 and VR1.
My guess, they defined V2 vertically with the positive end on the top and neglected to mention it.
It isn't up to us to arbitrarily define the voltages. Once you have shown eqn (2) is true, and eqn(3) is true, you have already been manipulated into defining the voltages the way the authors intend. The upshot is that eqn(4) needs that extra - sign.
kostoglotov, in future could you reduce the size of images. You can probably see how your over-size image in this thread causes the browser to shrink the page (and along with it, the text) so the full image fits onto the screen?
good point... only [(2) and (3)] or [(4)] can be correct
then assuming op presumed 2 and 3 are correct, then yea 4 is missing a (-) sign.
No worries. I don't notice what you're seeing, perhaps because I'm using a large monitor?...I'll keep it in mind.
Exactly, eqn 4 needs to have that missing - sign if we are to accept the previous equations. So, I need to take this back to the tutor or professor.
