Why aren't plot legends showing with Show in Mathematica?
  • Topic: Mathematica
  • Thread starter Thread starter Ishika_96_sparkles
    Quantum
4 replies · 5K views · last reply
Ishika_96_sparkles
TL;DR
I plotted a few curves for the wavefunction of Quantum Harmonic oscillator problem with certain energy values. The plotlegends do not seem to work in the final output.
Here, are the parts of the plot function[CODE title="plot I"]p1 = Plot[Normal[g*Exp[-x^2/2] /. solute[[1]] /. en -> 3], {x, -8, 8},
PlotStyle -> {Dashed, Gray}, PlotLegends -> Automatic];
(* Here, g=1 - x^2 - x^4/6 - x^6/30 - x^8/168 - x^10/1080 , energy en =3 and solute is the series solution of g with unknown coefficients*)[/CODE][CODE title="plot II"]p2 = Plot[
Normal[g*Exp[-x^2/2] /. solute[[1]] /. en -> 10], {x, -8, 8},
PlotStyle -> {Dashed, Red}, PlotLegends -> Automatic];
(* Here, g=1 - (9 x^2)/2 + (15 x^4)/8 - x^6/16 - (3 x^8)/896 - x^10/3840 *)[/CODE]
[CODE title="plot III"]p3 = Plot[
Normal[g*Exp[-x^2/2] /. solute[[1]] /. en -> 17], {x, -8, 8},
PlotStyle -> {Thick, Black}, PlotLegends -> Automatic];
(* Here, g= 1 - 8 x^2 + 8 x^4 - (32 x^6)/15 + (16 x^8)/105 *)
[/CODE]
and then the SHOW command as follows
[CODE title="Show command"]
Show[{p1, p2, p3}, PlotRange -> All,
LabelStyle -> Directive[Blue, Italic, 12]][/CODE]
What did I do wrong, here?
The plots with no legends for the curves.
Try plotting one at a time and see if the plot legends appear then add one plot and try again.
If they appear on the first plot but not the 2nd or 3rd then you know where your error might be.
You could also try plotting them in reverse order.
The basic idea is to see if its the way you specified plot legends in each plot call vs a mistake in a plot that somehow hides the plot legend.
Also have you searched via google to see if others have had the same issue?
Here's what I found about plotlegends:
https://reference.wolfram.com/language/PlotLegends/ref/PlotLegend.html
In one example they do two plots in one call so maybe that's what you have to do.
Thanks @jedishrfu
I shall try your suggestion and see if it works and then post the working solution here.
So, this is the way i have learned to do it for the SHOW command
(I checked the plots individually and the PlotLegend worked fine. However, I found the following way to be more clean than filling the plot command with most of the attributes.)
[CODE title="Use of Legended" highlight="LineLegend"]
Legended[Show[p1, p2, p3, PlotRange -> All],
Placed[LineLegend[{Gray, Red,
Green}, {"\!\(\*SubscriptBox[\(\[Psi]\), \(2\)]\)(x)",
"\!\(\*SubscriptBox[\(\[Psi]\), \(6\)]\)(x)",
"\!\(\*SubscriptBox[\(\[Psi]\), \(8\)]\)(x)"}], {.9, .8}]][/CODE]
The numbers in the curly brackets are the position coordinates {x,y} of the placement of the legend for the curve. The output is given below. Thanks a lot for the help!
Plot of three oscillating curves against x from about -7 to 7, with a legend listing psi_2(x) grey dashed, psi_6(x) red solid, and psi_8(x) green dashed; amplitudes peak near 1.5 and dip near -1.5.
Thanks for your analysis, solution and insight. It’s always great to see that in a thread And will help future readers who stumble across it in their search for answers.
