Why aren't stars in a star cluster attracted to each other?
  • Context: Undergrad
  • Thread starter Thread starter texasblitzem
    Star Stars
The discussion revolves around the dynamics of stars within globular clusters, specifically addressing why stars do not collide despite gravitational attraction. Participants explore concepts related to gravitational interactions, orbital mechanics, and the nature of stellar motion within these clusters.
  • Exploratory, Technical explanation, Debate/contested, Conceptual clarification
  • Some participants assert that stars in a globular cluster do attract each other gravitationally, but they do not collide due to their relative motions, similar to how Earth does not crash into the Sun.
  • Others propose that if stars were to collide, it would not result in a mega-star but rather a black hole.
  • There is a discussion about whether the motion of stars in a cluster can be described as rotation, with some arguing that the stars orbit a common barycenter while others suggest that the lack of uniform angular momentum complicates this view.
  • Participants share insights from simulations indicating that actual collisions between stars are rare and require precise conditions, as stars tend to interact gravitationally without direct collisions.
  • Some participants question the stability of orbits in a cluster, suggesting that stars may follow chaotic paths influenced by close encounters with other stars.
  • There is debate over the definition of "orbit," with some defining it as a periodic path while others argue that non-periodic paths can also be considered orbits under certain conditions.
  • Quantitative approaches to estimating collision rates and the dynamics of star interactions are discussed, highlighting the complexity of gravitational effects in dense stellar environments.
Participants express a range of views on the nature of stellar motion in globular clusters, with no consensus reached on definitions of orbits or the implications of chaotic paths. The discussion remains unresolved regarding the stability of orbits and the conditions under which stars may collide.
Limitations include varying definitions of orbits, assumptions about stellar interactions, and the complexity of gravitational dynamics in dense clusters. The discussion also touches on the implications of chaotic motion and the potential for stars to escape the cluster.
texasblitzem
If a globular cluster is a dense(relatively speaking) collection of stars, why don't the stars attract each other gravitationally? Why don't they all collide to form a mega-star?
Astronomy news on Phys.org
They do attract each other gravitationally. They don't all crash into one another for the same reason the Earth doesn't crash into the sun.
If they all collided and merged it wouldn't result in a mega star. It would be a black hole that would be created.
It is not that I'm a expert on astronomy. But isn't that the same as saying the cluster is rotating?
I'm not an expert either, but I was playing with someone's orbital simulation software once where you could define any number of planets and stars and set their initial velocities, etc., and you then see how they all interact. I noticed that it is very difficult to get interstellar objects to collide. They have to hit practically dead-on. Otherwise they just whip around each other.
Obviously, if that were to happen in real life there would be severe damage to both bodies in terms of atmospheric and other disturbances. But literal collisions are hard to do even when done on purpose.
^ this is true
Even when 2 galaxies merge, there are only a few of the billions of stars that actually collide, otherwise they just swing around each other.
Of course. The stars in the cluster are moving around each other, all orbiting the barycenter of the cluster.
That doesn't mean that the cluster is rotating because the orbital angular momentums doesn't have the same direction. Star clusters usually have no total angular momentum. In addition the trajectory of the stars doesn't have to be orbits.
Is it being suggesting that stars in a globular cluster might be oscillating like bees in a hive?
Respectfully,
Steve
That's a nice analogy but the motion of the stars is determined by the common gravitational field and not by aerodynamics.
I'm not saying every star will be moving in the same direction, only that they will be moving around in orbits. If the trajectory isn't in an orbital then the star will escape the cluster. Unless I'm misunderstanding the way orbit is being used here.
How about a chaotic path due to many close flybys?
As was pointed out earlier, cluster stars seldom collide with each other. Let's try to quantify this result.
Collision rate = (number density of targets) * (collision cross section) * (velocity)
For stars with radius r separated by distance a and traversing their separation distance in time T, the rate becomes
(1/T) * (r/a)2
One has to be careful of gravitational effects, since the stars will be pulled together before they collide. This changes the cross section from pi*r2 to
pi*r*(r + 2(G*M)/(v2))
for mass M and velocity at infinity v. Even then, it's easy to show that collisions are rare.
Isn't that an orbit still? It's still bound to the cluster.
One can estimate the likelihood of close flybys per orbit.
The average orbit speed ~ sqrt(G*M/A)
M = total mass, A = total size
For N stars, they are related to individual mass m and separation a as
M ~ N*m
A ~ N1/3*a
To be deflected significantly, a star must pass within about G*m/v2 of another star, and that is about A*(m/M) or A/N.
A star's mean free path, its travel distance between such deflections, is
1/((stars' number density) * (deflection cross section))
Working it out, 1/((N/A3) * (A/N)2) or N*A.
So a star will make on average about N orbits between sizable deflections.
Maybe they're not the right type.
*Groan* Terrible joke!
You're using a different definition of the word orbit than I'm used to.
It's a good question.
I am not sure if orbits are really stable in a cluster where the orbits have a wide distribution of planes.
For any given star, as long as it does not manage to acquire enough velocity to actually escape the cluster (and it's entirely possible some do) it could happily drift around on an highly unstable path.
Yup, maybe! I found this in wiki:
"The results of N-body simulations have shown that the stars can follow unusual paths through the cluster, often forming loops and often falling more directly toward the core than would a single star orbiting a central mass. In addition, due to interactions with other stars that result in an increase in velocity, some of the stars gain sufficient energy to escape the cluster."
http://en.wikipedia.org/wiki/Globular_cluster
Respectfully submitted,
Steve
It is not periodic.
My definition for orbit is a periodic path around a point in space. What is yours?
On average. But in the core of the cluster close encounters are much more common. In case of a core collapse the number of such events increases dramatically (compared to the average) so that formations of double stars lead to a significant increase of the "temperature" of the whole cluster.
Are hyperbolic orbits not orbits?
You mentioned chaos...
If those chaotic paths are closed, are they not orbits?
To my understanding of "orbit" they are not. But I checked that and found some sources that uses this word also for open trajectories. Do you have a source for an official definition of this word?
A closed chaotic path is very unlikely.
DrStupid said:
It is not periodic.
Alright, that's a fair statement. Instead of "orbit" can I just say they are all attracted to the cluster and follow different trajectories around it? Obviously interactions with individual stars will cause each star to follow a possible wildly varying trajectory.
  • · Replies 26 ·
  • · Replies 53 ·
9K
  • · Replies 28 ·
  • · Replies 0 ·
