Why can coefficient "a" between spacetime intervals depend on velocity between systems?
42 replies · 9K views · last reply
Sagittarius A-Star said:
  1. The absolute value of relative velocities is in both cases not ##4m/s##. If the individual velocities of your 4 frames refer to a certain unnamed inertial reference frame, then you must use the relativistic velocity addition formula.
  2. From equation ##(2.6)## in the scan in the OP (posting #1) follows ##ds_2^2=ds_1^2## and ##ds_3^2=ds_4^2##.
At first, I consider two frames:
Frame 1: 1m/s Frame 2: 5m/s; (1-5)m/s and (5-1)m/s => absolute value of relative velocity is 4m/s
Then, I consider another two frames:
Frame 3: 2m/s Frame 4: 6m/s; (2-6)m/s and (6-2)m/s =>absolute value of relative velocity is 4m/s
What's wrong?
Mike_bb said:
What's wrong?
Relative velocity means the velocity one thing measures the other to have. Here, you've calculated the velocity difference between two things as measured by a third party (someone at rest in the unnamed frame in which you specified the velocities of frames 1-4), which I usually call the separation rate. In Newtonian physics the separation rate and relative velocity are the same but not in relativity, and you need to use the relativistic velocity addition formula.
For such low velocities as 4m/s the error will be on the order of one part in ##10^{16}##, but it does mean that your two pairs of frames don't have the same relative velocities. I didn't mention this because it makes no difference to the discussion of your ##K##, which is entirely about choosing consistent units. But @Sagittarius A-Star is correct to note that frames 1 and 2 will not measure the other to have the same velocity that frames 3 and 4 will.
(Edit: e.g. imagine I measure object A to be doing +0.9c and object B to be doing -0.9c. The separation rate I measure is 1.8c, but this cannot be the velocity that A measures B to have since it exceeds ##c##. To get the speeds they measure I would use the relativistic velocity addition formula$$u'=\frac{u-v}{1-uv/c^2}$$which predicts that A and B would measure the other to be doing about 0.994c. But at the velocities you specified for your frames the ##uv/c^2## term is tiny so the relativistic formula becomes ##u'\approx u-v##, which is the Newtonian result you implicitly used.)
On page 5 according to your screenshot you can conclude from the first sentence, that ##a## must be constant. L&L doesn't explain this, but in the 1960 book "Special Relativity" of Wolfgang Rindler, he did it in §8, page 16:
Hello!
I read about irreducible polynomials and constant factor between them but it was written that polynomials were depended of the same variables. For example, P(x) and Q(x), but in the case of the example we have two polynomial with different variables: P(dt, dx,dy,dz) and Q(dt',dx',dy',dz'). Why does it work in this case?
Thanks.
Mike_bb said:
Hello!
Thanks.
As written in the screenshot, this works because the transformation is linear. Therefore, you can re-write all primed variable in terms of the unprimed variables in the following way:
##t' = Ax+By+Cz+Dt## and so on. This means you can write both polynomials so, that they depend on the same variables.
Mike_bb said:
Perhaps there is mistake in the book:
Maybe: ##P=aT'^2+bX'^2+cY'^2+dZ'^2 +....##
No, see above in posting #35.
Sagittarius A-Star,
Hello!
I argued with one person that "differentials" (as is mentioned in the book) = "infinitesimally small displacement". Google says that it's true, but person say that it's false.
Which of us is right?
Thanks.
Neither of them are valid references here. Can you find a reference that is valid? Like, say, a textbook on calculus that gives a rigorous definition of the term "differential"?
I have this source only:
I can't give rigorous definition of the term "differential" because its depend on context.
Thanks.
Maybe this helps:
Wikipedia said:
The term differential is used nonrigorously in calculus to refer to an infinitesimal ("infinitely small") change in some varying quantity. For example, if x is a variable, then a change in the value of x is often denoted Δx (pronounced delta x). The differential dx represents an infinitely small change in the variable x. The idea of an infinitely small or infinitely slow change is, intuitively, extremely useful, and there are a number of ways to make the notion mathematically precise.
Source:
https://en.wikipedia.org/wiki/Differential_(mathematics)#Introduction
Approaches for making the notion of differentials mathematically precise:
https://en.wikipedia.org/wiki/Differential_(mathematics)#Approaches
PeterDonis said:
From where?
It is from Wolfgang Rindler.
https://www.amazon.com/Introduction-to-Special-Relativity/dp/0198531818?tag=pfamazon01-20
For details, see:
