Why Can't S² Have a Globally Flat Geometry?
17 replies · 5K views · last reply
Discussion
arkajad
- 1,481
- 4
quasar987 said:Because it would mean that there is a diffeomorphism S^2 -->R^2
Well, an infinite cyllinder has a globally flat geometry, but there is no diffeomorphism from the cylinder onto R^2.
But you may check this ion Wikipedia: "Vector fields on spheres". Global flatness of S^2 would imply existence of two nowhere vanishing vector fields.
- 771
tom.stoer said:Quick question: from which topological consideration can one derive the fact that a sphere S² does not allow for a globally flat geometry?
A flat manifold must have Euler characteristic zero.
This is the content of the Gauss Bonnet theorem.
One can prove that every compact flat Riemannian manifold is covered by flat euclidean space by the action of a group of isometries. Such groups are known as Bieberbach groups and are extensions of lattices by finite groups.
The sphere on the other hand can not be covered by anything but itself because it is simply connected. So it can not be flat.
The only compact flat surfaces without boundary are the flat torus and the flat Klein bottle. In each dimension there are finitely many compact flat Riemannian manifolds. I know that all of the 3 manifolds have been determined and maybe all of the 4 manifolds as well - not sure. Generally, it is daunting to try to calculate all of the flat manifolds in a high dimension.
More generally whenever you have a flat bundle (in this case the tangent bundle of the flat manifold) whose connection is consistent with a Riemannian metric, the Euler class of the bundle is zero. On the other hand there are examples of flat bundles - even over surfaces - whose connections do no derive from a metric and whose Euler class is not zero.
A simple realization of the flat torus in the unit 3 sphere is the set of points (1/2^.5)(sin x, cos x, sin y, cos y).
So the flat torus can be embedded in 4 dimensions. It would be interesting to know if the same is true of the flat Klein bottle - maybe not.
- 771
quasar987 said:Ok, I thought globally flat meant there exists a global isometry from S^2 + some metric to R^2 + usual metric.
Globally flat means that the curvature tensor is identically zero.
A global isometry would be a diffeomorphism. The flat torus is not diffeomorphic to R^2.
- 174
@lavinia: thanks for reminding me to these facts
Let me see if I understand. The Euler characteristic of S² is 2. This can be seen by using a triangulation on S² or by calculating
[tex]\chi_{S^2} = 2 - 2g_{S^2}[/tex]
and using
[tex]g_{S^2} = 0[/tex]
But by Gauss-Bonnet we know that
[tex]\chi_{S^2} = \frac{1}{2\pi}\int_{S^2}K[/tex]
Global flatness would imply [tex]K = 0[/tex] globally which results in [tex]\chi_{S^2} = 0[/tex] which is a contradiction.
and using
- 771
tom.stoer said:@lavinia: thanks for reminding me to these facts
and using
right. the Gauss Bonnet theorem works in all dimensions. There is a differential form which is a polynomial in the curvature 2 form that equals the Euler class of the tangent bundle.
- 771
arkajad said:Well, an infinite cyllinder has a globally flat geometry, but there is no diffeomorphism from the cylinder onto R^2.
generally global flatness only implies the existence of one nowhere vanishing vector field. On an oriented surface, on can rotate one vector field to get another but generally there is no way to do this. On an unorientable surface for instance, this does not work. The Klein bottle has only one independent non zero vector field and yet it admits a flat metric.
- 771
On flat surfaces, there is not only a non-zero vector field but the field can be chosen to always be tangent to geodesics - the projections of lines in the plane into the surface. I wonder if this always true of a flat manifold. It is certainly true if the first Betti number of the manifold is not zero.
arkajad
- 1,481
- 4
lavinia said:generally global flatness only implies the existence of one nowhere vanishing vector field.
S^2 is two-dimensional, connected and simply connected. You choose two orthonormal tangent vectors at one point and transport them using parallel transport to every other point. This transport is path independent (zero curvature plus topology). This way you would get two orthonormal vector fields. While by Adams' theorem even one does not exist.
- 771
arkajad said:S^2 is two-dimensional, connected and simply connected. You choose two orthonormal tangent vectors at one point and transport them using parallel transport to every other point. This transport is path independent (zero curvature plus topology). This way you would get two orthonormal vector fields. While by Adams' theorem even one does not exist.
this is wrong. There are no independent vector fields on the 2 sphere. Further the sphere does not have zero curvature.
There are no simply connected compact flat Riemannian manifolds.
- 174
By inspection of 2-2g = 0 only g=1 allows for globally flat geometries.
Another related question: The Gauss-Bonnet theorem restricts the existence of globally flat geometries. What about the other way round? Suppose I have a manifold for which I can proof that the Euler characteristic vanishes. Does this automatically guarantuee that a globally flat geometry must exist? I guess not, but what are the other restrictions?
arkajad
- 1,481
- 4
lavinia said:this is wrong. There are no independent vector fields on the 2 sphere.
1) That is what I was saying, assuming hypothetically global flatness - as in the original question. Proof by contradiction. There is not even one.
2) Whether a given manifold is globally flat or not depends on the Riemannian metric. R^2 can be made globally flat and can be made non-flat even locally. Up to you.
- 771
tom.stoer said:By inspection of 2-2g = 0 only g=1 allows for globally flat geometries.
Absolutely not. There are many manifolds of zero Euler characteristic.
Take any manifold and take its Cartesian product with a circle.
If a compact manifold is flat then all of its Stiefel Whitney numbers must be zero. But there are many non-flat manifolds of zero euler charateristic and all zero Stiefel Whitney numbers so this does not suffice.
the mod 2 reduction of the Euler characteristic is the top Stiefel Whitney number but there are many other Stiefel Whitney numbers as well.
- 771
arkajad said:1) That is what I was saying, assuming hypothetically global flatness - as in the original question. Proof by contradiction. There is not even one.
OK. Didn't understand what you were getting at.
A simply connected globally flat manifold can not be compact. The only example is Euclidean space.
- 771
I doubt that there are conditions on Characteristic classes that guarantee that the manifold has a flat a metric. For instance the sphere cartesian product with a circle has zero Euler characteristic and all zero Stiefel Whitney numbers.
Flat manifolds have finite holonomy group - so the structure group of the tangent bundle is finite - this is an extremely strict condition.
Graduate
Can a sphere have flat geometry?
- Hoku
- · Replies 5 ·
- Differential Geometry
- Replies
- 5
- Frank Castle
- · Replies 40 ·
- Replies
- 40
- timmdeeg
- · Replies 5 ·
- Special and General Relativity
- Replies
- 5
