Why Convert Equations to Parametric Form?
  • Context: Undergrad
  • Thread starter Thread starter Fuz
6 replies · 20K views
Fuz
How do you take an equation and turn it into a parametric one? Eliminating the parameter is straightforward and easy; but I'm trying to go the other way.
e.g. what steps would one take to convert some curve like
y = x2
or
x2 + y2 = 1
into parametric equations with 't' as the independent variable?
There are number of ways, for conics, some traditional ways are:
For y=x2; x=t, y=t2.
For x2+y2=1; x=cost, y=sint.
What was your motivation for setting x = cos(t) and y = sin(t)? Is there a method for turning an equation into a set of parametric equations?
actually, eliminating the parameter is equally hard. If the equation is in an explicit form [itex]y = f(x)[/itex], then, whatever you take as a parametric representation of x, [itex]x = \phi(t)[/itex], you can find [itex]y = y \left[ \phi(t) \right] = \psi(t)[/itex]. In other cases, there is no general rule. For example, eliminate the parameter in:
[tex] x = t \, \cos t, \ y = t \, \sin t[/tex]
describing an Archimedian spiral.
You hopefully have learned that [itex]cos^2(t)+ sin^2(t)= 1[/itex]. Comparing that to [itex]x^2+ y^2= 1[/itex] should make the parameterization obvious. But there is no general way of parameterizing (except that if y= f(x), you can always use x= t, y= f(t)).
Hey Fuz.
On top of what the other posters have said, it does help immensely if you know the dimension of the system.
If you are dealing with a one-dimensional system (like a line), then there are techniques that you can do to make a move towards getting a complete analytic parametrization.
Yes I have learned this, and that basically answered my question, but then what is the point in just setting x equal to t?
