Why Convert Equations to Parametric Form?
  • Context: Undergrad
  • Thread starter Thread starter Fuz
The discussion revolves around the process of converting equations into parametric form, specifically focusing on curves such as parabolas and circles. Participants explore methods, motivations, and challenges associated with this conversion, touching on both theoretical and practical aspects.
  • One participant inquires about the steps to convert equations like y = x² and x² + y² = 1 into parametric equations using 't' as the independent variable.
  • Another participant suggests specific parameterizations for the given equations, proposing x = t and y = t² for the parabola, and x = cos(t) and y = sin(t) for the circle.
  • A question is raised regarding the motivation behind choosing x = cos(t) and y = sin(t), and whether there is a systematic method for creating parametric equations from a given equation.
  • One participant argues that eliminating the parameter can be complex, particularly when the equation is not in explicit form, providing an example of an Archimedean spiral.
  • Another participant emphasizes the importance of understanding the dimensionality of the system when seeking a complete analytic parameterization.
  • A participant expresses confusion about the utility of simply setting x equal to t, questioning its purpose in the context of parameterization.
Participants express varying views on the methods and motivations for parameterization, with no consensus on a single approach or the best practices for converting equations into parametric form. The discussion remains unresolved regarding the generality of parameterization techniques.
Participants note that there is no universal method for parameterizing equations, and the effectiveness of certain approaches may depend on the specific form of the equation and the dimensionality of the system.
Fuz
How do you take an equation and turn it into a parametric one? Eliminating the parameter is straightforward and easy; but I'm trying to go the other way.
e.g. what steps would one take to convert some curve like
y = x2
or
x2 + y2 = 1
into parametric equations with 't' as the independent variable?
There are number of ways, for conics, some traditional ways are:
For y=x2; x=t, y=t2.
For x2+y2=1; x=cost, y=sint.
What was your motivation for setting x = cos(t) and y = sin(t)? Is there a method for turning an equation into a set of parametric equations?
actually, eliminating the parameter is equally hard. If the equation is in an explicit form y = f(x), then, whatever you take as a parametric representation of x, x = \phi(t), you can find y = y \left[ \phi(t) \right] = \psi(t). In other cases, there is no general rule. For example, eliminate the parameter in:
<br /> x = t \, \cos t, \ y = t \, \sin t<br />
describing an Archimedian spiral.
You hopefully have learned that cos^2(t)+ sin^2(t)= 1. Comparing that to x^2+ y^2= 1 should make the parameterization obvious. But there is no general way of parameterizing (except that if y= f(x), you can always use x= t, y= f(t)).
Hey Fuz.
On top of what the other posters have said, it does help immensely if you know the dimension of the system.
If you are dealing with a one-dimensional system (like a line), then there are techniques that you can do to make a move towards getting a complete analytic parametrization.
Yes I have learned this, and that basically answered my question, but then what is the point in just setting x equal to t?
