The question is: What factors determine the acidity of a molecule?
  • Thread starter Thread starter gangsterlover
    Acids Protons
The acidity of a molecule is fundamentally determined by its ability to donate protons, which is influenced by the stability of the resulting species and the energetic costs associated with proton removal. Key factors include the strength of the -O-H bond, the position of relevant atoms in the periodic table, and the oxidation state of atoms. Understanding these concepts is essential for grasping acid dissociation and the systematic tendencies of acidity in organic compounds. Resources such as the Purdue University Chemistry website provide valuable insights into these factors.
  • Understanding of acid-base definitions, specifically Brønsted acids.
  • Familiarity with chemical bonding, particularly -O-H and C-H bonds.
  • Knowledge of periodic table trends and atomic properties.
  • Basic concepts of thermodynamics in chemical reactions.
  • Explore the Bronsted and Hammett relations to understand acidity quantitatively.
  • Research the factors affecting acid dissociation constants in various chemical contexts.
  • Study the systematic trends of acidity in organic acids and their relation to electron density.
  • Review the Purdue University Chemistry resources on acidity and chemical reactions.
Chemistry students, educators, and professionals seeking to deepen their understanding of acid-base chemistry and the factors influencing molecular acidity.
gangsterlover
Title says it all.
I don`t get it.
Chemistry news on Phys.org
What you don't get? That's the way they behave. It is not different from any other chemical reaction. Why does the AgCl precipitate from the solution? Why does chlorine oxidize sodium? Why does carbon burn in oxygen? We have thermodynamical explanations, but they don't change the fact that it happens because it happens.
Then, we happened to call substances that donate protons acids. We could as well call them guripsestrudomes.
what causes the acids to donate protons is what I am interested in.
Sorry, but you don't make the question better defined by repeating it. As I already wrote - forces behind the acids donating protons are exactly the same ones that are behind any other chemical reaction. For some reasons products are more stable, or get separated (so that backward reaction is unlikely) and so on. Acid dissociation is in no way different.
Yes, I thought yesterday of answering in the same way - they are obliged to donate protons by definition. At least for about the last 80 years. Anything that doesn't donate a proton is not called an acid.
I held back because that would not have been very helpful, but from the chemist's point of view you did need, as Borek says, to ask a more meaningful question. Maybe better would have been: why is anything an acid? Which is again as Borek says a part of the question why does any chemical reaction happen?
You are asking us to write chapters of your textbook.
But roughly some bonds - the -O-H bond looms large, are weak enough that they will permit significant dissociation into -O- or rather, it is better to think of it as, transfer of a proton to water
X-O-H + H2O → X-O- + H3O+
Whereas there is no significant such dissociation of a C-H bond except for very special unusual cases.
(The removal of the proton has an energetic cost, but when it happens it is also because in compensation the charged species created attract and are attracted by water molecules that being dipolar, the oxygen atom having a partial negative charge and the H atoms a partial positive one) orient themselves around the created charges. This factor is not sufficiently emphasized in explanations, nor it it easy to calculate quantitatively.)
What you need to have an eye for, especially since such things as dissociation constants are very difficult to predict quantitatively, is the tendencies, how the acidity of molecules varies systematically according to: position of the relevant atoms in the periodic table, across and up and down, and the oxidation state of atoms. The explanation given to the main tendencies are succinctly summarised here.
http://chemed.chem.purdue.edu/genchem/topicreview/bp/ch11/factors.php#top
In organic acids there are also, perhaps clearer, systematic tendencies to learn about and there are clear quantitative relations between acidity as tendency to donate a proton and other manifestations of electron density in other chemical reactions (read up about Bronsted and Hammett relations).
You will find these things quite a lot emphasized in chemistry teaching and examinations :biggrin: so it would do you some good to follow up your curiosity by reading up these things and having them present continuously as you go throughout things like chemistry of the elements, organic acids etc. Do not be surprised if not everything rationalises completely, I have hinted why.
