Why do photons have no rest mass and cannot have a charge?
  • Context: Graduate
  • Thread starter Thread starter Nikaro
    Charge Photon
The discussion centers on the nature of photons, specifically addressing why they have no rest mass and cannot possess electric charge. Participants explore theoretical implications, properties of photons, and comparisons with other particles, including the W bosons and quarks. The conversation includes both conceptual and technical elements.
  • Some participants suggest that photons are massless because only massless particles can travel at the speed of light.
  • Others mention that the gauge symmetry group of electromagnetism (U(1)) implies that photons cannot have charge.
  • One participant introduces the idea that W bosons, which have mass and charge, are different from photons.
  • There is a discussion about the possibility of photons having mass if they couple to another scalar field, raising questions about charge conservation and U(1) invariance.
  • Some participants argue that photons should be viewed as electromagnetic waves and pure energy, which provides insight into their lack of mass.
  • There is a debate about whether photons can be considered particles in the traditional sense, with some participants questioning the definition of "traditional particle."
  • One participant asserts that since photons have no rest mass, they cannot carry charge, while another points out that confined photons can contribute to the mass of a system.
Participants express a range of views regarding the properties of photons, with no consensus on several points, including the implications of mass and charge, and the definitions of particles. The discussion remains unresolved on many aspects.
Some statements rely on specific definitions and assumptions that may not be universally accepted, such as the interpretation of "pure energy" and the implications of gauge symmetry. The discussion includes speculative ideas about the nature of mass and charge in relation to photons.
Readers interested in particle physics, the properties of light, and the theoretical frameworks surrounding mass and charge in quantum mechanics may find this discussion relevant.
Nikaro
Why photon exist without rest mass and why it can never have a charge. Plz reply.
well physics tend not to answer all "why" questions, we can only move them to a different level.
i) the photon moves at the speed of light, only massless (i.e. 0 rest mass) can do so
ii) The gauge symmetry group of electromagnetism is U(1), which is abelian, thus the photon has not charge.
Then you can ask why it moves at the speed of light and why EM has U(1) gauge symmetry group and so on.
There are however "photons" with charge and mass, the W- and W+ bosons. (Roughly speaking of course)
Please explain it simple i can't under stand above reply
and I don't understand what part of them you did not grasp or at what level you currently are at. What is "simple" is relative...
Photon is a wave, it travels. In vacuum it travels fast (v=c), in a transparent medium (glass, water) it travels slower, with v<c, so there is an accompanying reference frame where it looks as a standing wave. Despite that it still have energy ћω. You can assign some mass to it, if you like.
Photon carries energy-momentum. It can transfer part of them to another particle or system. Photons strongly interacts with charged particles: roughly speaking, photon is an electric wave. Photon practically does not interact with another photon in vacuum. It is due to the principle of superposition of electric fields, if you like. Electric fields make only sense when they appear in the particle equation motion as external forces.
Bob_for_short.
I was wondering the same thing.
In Love
Prys die Heer!
Thanks everybody.
Keeping with the theme of particle physics, the question should really be why other particles have mass (and why they have the value of the mass that they have), rather than why doesn't the photon have mass. 0 is easy to understand.
Mass is related to the spontaneous symmetry breaking of a scalar Higgs. The photon gains no mass as it is the gauge field corresponding to a direction in field space where symmetry is not broken from the electroweak phase transition. For more information there is plenty of material on the web about the Higgs mechanism.
The photon could still be massive if it couples to another scalar and gains mass that way:
http://arxiv.org/abs/hep-ph/0306245
If the photon has a small mass that is generated by such a Higgs mechanism, then it turns out that the very sharp upper bounds on the photon mass that depend on the vector potential of the galactic magnetic field, are not valid.
So I assume this other scalar would develop a vacuum expectation value that will be a different value than usual one, i.e., the one whose ground state is U(1) charge invariant and gives mass to the Standard Model. But if this happens, then don't you lose conservation of charge, since your theory will lose U(1) charge invariance?
Maxwell's equations do admit massive solutions "propagating" with the speed of light! however, these solutions are trivial. They are not observable, because one can always gauge them away.
regards
sam
Actually, the article assumes that the ordinary Higgs mechanism would generate the photon mass. Anyway, you still have a conserved current, even in Proca theory, as the article explains.
The Photon is an electro-magnetic wave and thus should be viewed as pure energy to understand it better, this will give insight into the no mass question, different particles are in simple a combination of a set mass ratio to their energy at ground state. The absorbsion of a photon in a particle will raise its energy state and then subsequently releases the exact energy out as a duplicate photon, this happens almost instantaneously but a fragment of time is used thus the speed of light through air liquid and solids becomes increasingly slower.
ohh Define pure energy please
Are photons made of quarks?
no they are made of air
Quarks have mass. Photons don't have mass.
Quarks have electric charge. Photons don't have electric charge.
Quarks interact strongly. Photons don't interact strongly.
Quarks interact weakly. Photons don't interact weakly.
So no, photons are not made of quarks.
Thanks.
So photons aren't really particles in the traditional sense are they?. Their particle nature is just a reflection of the quantization of their energy.
Sidnv said:
Thanks.
define "traditional particle" ...
I guess i can't really give an exact definition. I would say that traditional meant non zero rest mass but that's hardly a traditional definition.
Then why using home-made defition of things when writing in a physics forums where we are trying to discuss current accepted physics (see forum rules) ?
I apologise. I was just curious and I'm new to this.
it's ok, see also the term "pure energy" invented by darkwood in this thread.
Energy has mass.
Charge has energy, so charge has mass.
Charge is something that still exists while it is at rest, so charge has rest mass.
Since the photon has no rest mass, it can't carry a charge (because if it carried a charge it would have rest mass).
(Note that a confined photon in a mirrored box gives that box rest mass. We call that mass contribution the photon's "relativistic mass". But that mass is strictly caused by the photon's kinetic energy--the photon has no rest mass)
fleem said:
Energy has mass.
That's simply not true.
If it were true, photons would carry no kinds of charges at all. But they carry something called weak hypercharge.
charge "has" energy is wrong also..
My understanding was that - light traveling @ <c through materials due to photon absorption/re-emission - was not the accepted explanation.
I saw someone say this same explanation without comment another time so I'm starting to wonder if I got that wrong too?
I thought it was due to other factors? Was it something to do with space-time or was it magnetic interaction? I can't remember? Or is absorption/re-emission it?
It's all jumbled up, I'm afraid.
  • · Replies 20 ·
  • · Replies 0 ·
