Why do shapes with the same area have different perimeters?
21 replies · 6K views · last reply
SSG-E
TL;DR
For example, Consider two shapes; a circle and rectangle.
Both these shapes have same area but the perimeter of circle is less than that of rectangle. Why?
Side-by-side diagrams: a circle with radius 5 cm, labelled Area = 78.54 cm² and Perimeter = 31.42 cm; and a rectangle with sides r and πr, labelled Area = 78.54 cm² and Perimeter = 41.42 cm.
Take a loop of string or a rubber band and play around with it. It will give you a feeling as to why a constant perimeter can result in different areas.
I don't know what kind of answer you are looking for. It's obvious from geometry that there are many possible shapes with the same area and different perimeters. If I make a very long skinny rectangle of a given area, I can make the perimeter as large as I want. I don't know what kind of answer to give to your question except, "that's the way the geometry of our universe works."
SSG-E said:
Summary:: For example, Consider two shapes; a circle and rectangle.
Or, try to find an example of two different shapes that have the same area and the same perimeter.
none
I mean is it something related to the sides of the shapes?
The answer is trivially yes.
Start with a simple problem: consider a rectangle with sides of length ##a## and ##b##. The area is given by ##a \times b## while the parameter is ##2 (a+b)##. Do you see how a quantity that changes with the product of variables behaves differently than a quantity that changes with the sum of those variables?
yes
SSG-E said:
none
There are examples, but they are a bit harder to find. A triangle and a suitable trapezoid are the easiest examples.
t
triangles in some cases?
Another exercise would be to try and prove which shape maximises ##\frac{\text{Area}}{\text{Perimeter}}##. And what about ##\frac{\text{Volume}}{\text{Surface Area}}## in 3D?
Circle maximizes Area/perimeter. Sphere has the largest Volume/area.
It's right, but can you prove it? :wink:
In case of circle, it has infinite number of sides. In case of a sphere, For example, balloons are spherical, and they will assume the shape of minimum area
You can come up with some physical arguments which might show that the radius of curvature of a small region of the surface of an elastic balloon filled with a gas at a uniform pressure must be constant everywhere, implying a sphere.
For a more mathematical approach, you might look at something like this.
And what about the ratio area/perimeter for this shape?
Blue space-filling curve drawn on a square grid, forming a dense, self-similar pattern of loops that fills the square.
This is an example of a space-filling curve, a Sierpinski curve. The curve has a recursive definition, given one instance you can easily create the "next" and more complicated curve.
Maybe a high-powered answer is that neither area nor perimeter are topological properties, so are not preserved under deformations. Same would go the other way around, if you fixed a perimeter you can obtain figures of different areas. Maybe you can do something fancier and describe in a general way the relation between area and perimeter.
Thinking about it, two suitable trapezoids are a much easier example of two different shapes with the same area and perimeter.
It may be an issue of using isometries which I assume would be the operations that would preserve these. Topology vs Geometry.
I have in mind flopping between trapezoid to a parallelogram.
Please consider the following diagram:
Coordinate grid diagram of a large triangle ABC with a smaller triangle DEF cut out of its lower-left corner, shaded grey; the light blue region is the remainder between the outer and inner boundaries.
The light blue shaded area is less than that area plus the grey shaded area (i.e. the area of the whole ABC triangle), but because 'the shortest distance between two points is a straight line', the DF line segment is shorter than the DE plus EF segments, which makes the perimeter path of the light blue shaded area, ABCFEDA, longer than that of the outside triangle. ABCA. or ABCFDA, despite the smaller area of the region enclosed by the longer path.
