Why do some but not all derivatives have physical meaning?
The discussion revolves around the physical meaning of derivatives in the context of mathematical functions that describe physical phenomena. Participants explore the limits of derivatives, particularly in relation to position, velocity, acceleration, and higher derivatives, questioning when these derivatives lose their physical significance.
  • Some participants propose that while derivatives like velocity and acceleration have clear physical meanings, higher derivatives such as jounce may lack practical applications.
  • Others argue that the lack of applications does not equate to being meaningless, suggesting that meaning can be subjective.
  • A participant questions whether the derivative of jounce is truly meaningless or if it simply lacks a commonly recognized application.
  • There is a discussion about the integration of geometric shapes, with one participant suggesting that integrating the volume of a sphere could imply a description of a four-dimensional object.
  • Some participants note that mathematical operations do not inherently strip equations of physical meaning, as the meaning is defined by the context of the variables involved.
  • Concerns are raised about the relationship between mathematics and physics, particularly regarding the validity and applicability of mathematical theories in different physical contexts.
  • A participant mentions that higher derivatives, such as jounce and jerk, have applications in engineering, specifically in the design of cam shafts.
  • There is a philosophical inquiry into whether quantum mechanics and string theory represent mathematics or physics, suggesting a complex interplay between the two disciplines.
Participants express differing views on the significance of higher derivatives, with some asserting that they lack physical meaning while others contend that meaning is context-dependent. The discussion remains unresolved regarding the applicability and interpretation of these derivatives in physical systems.
Participants acknowledge that the utility of mathematical concepts can vary based on the physical context, and there are unresolved questions about the relationship between mathematical truths and their applicability in physics.
MiLara
I know that taking the derivative of certain functions that explain physical phenomena can lead to another statement describing the physical system, the most famous being the derivatives of position. That is,
position-->velocity-->acceleration-->jerk-->jounce...and taking any other further derivatives suddenly becomes physically meaningless. Is there any intuitive way of thinking about the "limits" of derivatives when it comes to describing physical or geometric systems?
What makes you say the derivative of jounce is physically meaningless? Is it physically meaningless just because you don't have a name for it?
I guess what I meant by meaningless is when it fails to have applications in terms of describing a physical system.
Do you know of any applications of the derivative of jounce?
Lack of applications isn't the same as meaningless. And it's subjective.
Suddenly? Doesn't the range of applications decrease with each derivative?
What would be the meaning if I integrated the volume of a sphere?
V=4/3pir^3 -----> 4/9pi^r4
What does this integral describe if anything?
I messed up..the integral would be 1/3pir^4 +c
You aren't asking meaningful questions.
I'm sorry for the vagueness.
I know that the derivative of the volume of the sphere is equal to the surface area of the sphere. That is intuitive to imagine, because with each infinitesimal change in the radius, it's like adding an infinitely thin coat of paint on the outside of the sphere, which would be the surface area. Also I note that if I integrate geometric shapes, one dimension is added.
Now let's say I were to integrate the volume of a sphere, would this give me a description of a 4 dimensional object, and if so, is it only unintuitive to us because we live in a 3 dimensional world? Or can higher dimensions be utilized in mathematics but not physics?
I have heard there are models describing n dimensions, usually would be associated with topology in the mathematics field, however. The integral you speak of in the quote would describe a 4-D volume, of infinitesimally summed together 3-D volumes. Any topologists that could give the proper term would be nice.
Anyway, it is not that each mathematical operation makes it physically meaningless. The meaning is already put into the equations, and that is by defining x and t. For the derivatives above:
x - position, t- Time
dx/dt = velocity = v - change in position x over change in time.
dv/dt = acceleration = a - change in the velocity.
da/dt = jerk = j - change in acceleration
and so on.
The mathematics may blur out the physics, but once you have a model described as differential equations, with each parameter and variable and function defined, the physics gets carried to the end result and would produce a relationship between them all, that would have a physical meaning.
Basically, if you have a meaning in the equation to begin with, the is no reason it would be lost.
A very fundamental issue which is not well taught. Not only does mathematics stand alone, if we lived in a very different universe, the utility of particular parts of math may be more or less useful, but math is not just separate from physics, when something is proved true in math, that's it. (Unless there is an error discovered later in the proof.) In physics, or any science, observations rule. Any beautiful theory can be destroyed by an ugly fact. More important, you may have a theory in physics that is believed true for hundreds of years before a contradiction is found.
Now for a disturbing question. Is quantum mechanics math or physics? What about string theory? Right now the best we can say is that there is a mathematics called QM which seems to correspond to the real world (actually QCD now). The same may be true of string theory, and even it may replace QM (technically as a physical theory) but the mathematics developed to support QM will still be true, even if string theory replaces QCD in physics. The disturbing question? Why does this math work so well?
The cam shaft in your car is designed using higher derivatives of position. Jounce or jerk is used at the peak and foot of the cam where the acceleration changes sign, higher derivatives are involved as well.
Quantum Mechanics might be something in between, like hyper-applied mathematics.
  • · Replies 18 ·
  • · Replies 233 ·
25K
