Why do we always see interference pattern in Michelson interferometer?
9 replies · 4K views
Salmone
In a Michelson interferometer with a monochromatic laser, why do we always see an interference pattern even if we move one of the mirrors?
Shouldn't it be a certain distance for which the movable mirror reflects the wave to be in opposite phase with the other wave so that they interfere destructively and we do not see anything on the screen?
Instead, I see in some videos that we always see an interference pattern and the only effect one see when moving the mirror is a change in this pattern but we still see light.
Shouldn't the movable mirror give in a certain position the same situation as the image?
Depends how you set up the interferometer. It's possible to set it up so that the wavefronts from the two arms are parallel planes, and then the screen varies from dark to light and back as you vary the path difference, as you seem to expect. However, it's quite difficult to use the interferometer in that mode. Exactly how dark is it? How do you recognise when you have 25% as much light as you do at maximum brightness? Your eye is lousy at that kind of estimation. Even if you have a digital camera you need to sample the adjacent maximum and minimum brightnesses to know where your brightness-of-interest lies between them.
So it's actually easier to tilt one of the mirrors slightly so that the path difference varies slightly across the field of view and you get straight line interference fringes. Then as you change the path difference the fringes flow across the screen, and you can get the path difference just by counting fringes passing a point. Or you can defocus the arms slightly so that curved fringes from one arm interfere with slightly differently curved fringes from the other. That gives you circular fringes that flow inwards or outwards as you adjust the path length. Again, counting fringes is easier than estimating how black the thing you're looking at is.
Thank you for your answer, while it's clear why we do this I still don't understand why this happen: how two waves don't interfere 100% destructively? In the first part of the answer you say: "It's possible to set it up so that the wavefronts from the two arms are parallel planes", so two waves do not cancel if they are spherical? How does it work?
vanhees71 said:
You don't have plane waves in nature!
Maybe I did not explain myself well, I try to rephrase the question:
why it is not possible to make two waves interfere totally destructively so that in a Michelson interferometer on the screen I see no more light? Is it because totally destructive interference would occur only in the case of plane waves, waves that in the interferometer we cannot use (since they do not exist in nature)?
It is possible (at least in principle - as @vanhees71 says, in practice there's always some curvature to the wavefronts). It's just not the best way to get quantitative data out of a Michelson interferometer, so you don't usually set it up that way.
To get perfect constructive or destructive interference you set the mirrors up perpendicular to one another. I've sketched wavefronts coming back along both arms, red in one and blue in the other, and you can see that they're parallel in the output arm on the left. This would be near-perfect constructive interference since both arms' waves are in phase (give or take my lousy free-hand sketching) (edit: and that I got the 45° mirror on the wrong diagonal, as noticed by sophiecentaur below):
But the usual operating mode is to tilt one mirror very slightly (you're looking to displace one side of the mirror a couple of wavelengths, about ##1\mathrm{\mu m}##) so you get constructive interference in some parts of the field and not others:
It's much easier to use in this mode, so nobody sets it up in the first mode. But you can do it.
Ibix said:
To get perfect constructive or destructive interference you set the mirrors up perpendicular to one another. I've sketched wavefronts coming back along both arms, red in one and blue in the other, and you can see that they're parallel in the output arm on the left. This would be near-perfect constructive interference since both arms' waves are in phase (give or take my lousy free-hand sketching):
It's much easier to use on this mode, so nobody sets it up in the first mode. But you can do it.
Thank you so much, now everything is clear.
The waves are actually spherical but the radius of the curvature is so great that it is possible to get cancellation over the width of the screen because the path lengths are near enough equal.
And when you have cancellation in one place, you will always have addition somewhere else.
Are you sure you've got the diagonal mirror the right way round?
It's... erm... reflected in... er... something.
I'll add a note to my post above - thanks.
