Why do Wigner's photon helicity states match gauge-fixed QED d.o.f.?
67 replies · 14K views
- 1,006
This reminds me of the problem of an electron in 2D with a constant magnetic field perpendicular to the plane. As the magnetic vector potential is only translation invariant up to a gauge transformation, one gets a projective rather than ordinary representation of E(2).
hch71
- 9
Gauge symmetry is not unrelated to Poincare symmetry at all.
the construction i like most is this: find the two Casimirs of the poincare group - they are the square of P and of the Pauli-Lubansky vector W. The first Casimir - p^2 - is the mass. p^2=m^2 gives you the Klein-Gordon equation. If the spin of your field is 0, that is all there is. If you have spin 1 however, you also get an equation from the second Casimir. This is the Proca equation or, for m=0, the (relevant half of the) Maxwell equations.
Now you realize that it is not possible to fulfill both at the quantum level and you have to chose a gauge, quantize one equation while implementing the second one as a constraint etc.
So the gauge symmetry follows directly from the Casimirs of the Poincare symmetry for spin-1 fields.
- 2,215
Hmm, I haven't seen a treatment that proceeds with the emphasis you describe. (I've seen treatments that start from Lagrangians, or treatments that use the Bargman-Wigner procedure to deduce features of spin-0 and spin-1 from direct products of spin-1/2 particles, but these seem a bit different from what you're saying, istm, and with a somewhat different emphasis from the usual Wigner classification of Poincare unirreps, unless I'm missing something.)hch71 said:Gauge symmetry is not unrelated to Poincare symmetry at all.
Could you please elaborate your answer a bit further, and/or suggest specific references for further reading?
- 1,006
strangerep said:The Wigner method for massless particles requires an additional input to be put in by hand: that there are no particle types in existence with (so-called) "continuous spin". (Personally, I find that term a bit misleading, but it's in wide usage even though Weinberg doesn't seem to use that phrase.)
Weinberg states that the continuous spin states for m=0 can be excluded for topological reasons, ie. a 4π rotation can be transformed along a continuous path into a 0 rotation whence only integer or non-integer spins are possible.
- 174
@hch71: you are right, there is again this strange relation between Poincare and gauge symmetry; for consistency reasons only specific dynamical models are allowed; quantum gauge symmetry is more restrictive than Poincare invariance.
Is this another coincidence? It is interesting that such a consistency condition shows up during regularization at the level of Slavnos-Taylor identities. I would expect an underlying principle (unfortunately unknown) which explains why gauge symmetry adds constraints to Poincare multiplets and why Casimir operators of Poincare symmetry tell something about the construction of gauge symmetries.
Both structrures are related via fiber bundels; Poincare acts on the base space, gauge acts on the fibers. But gauge and Poincare do commute, so the overall symmetry structure is a direct product w/o and relation at the level of Lie groups. Perhaps some unifying principle (SUGRA? strings?) can tell us more about such a hidden principle.
- 1,006
- 1,006
- 1,006
You are welcome!
If I understand correctly, the situation described in the book and the paper is analogous to the transition from the Lorentz Group to the homogeneous Galilei group. Mathematically this is an Inonu-Wigner contraction for the limit c to infinity. In that limit there also arises a gauge transformation, namely for the phase of the wavefunction whose generator is mass in Galilean relativity.
What is strange is that the massless representations appear as limits of the massive representations and gauge transformations as ghosts of rotations/ boosts around axes perpendicular to p. Somehow one would expect massless representations to play a fundamental role.
TrickyDicky
- 3,507
- 28
Last time I tried to make a connection between a spacetime symmetry and gauge symmetries (https://www.physicsforums.com/showthread.php?t=622084), I was reminded of the Colema-Mandula theorem, doesn't it apply here?tom.stoer said:@hch71: you are right, there is again this strange relation between Poincare and gauge symmetry; for consistency reasons only specific dynamical models are allowed; quantum gauge symmetry is more restrictive than Poincare invariance.
- 4,244
Well, it does apply, that's what Tom was saying that "gauge and Poincaré do commute, so the overall symmetry structure is a direct product w/o and relation at the level of Lie groups". That's the Coleman-Mandula theorem in a nutshell.
- 174
Yes.
And it's strange that Poincare and gauge symmetry are unrelated as Lie groups (and cannot be related due to the Coleman-Mandula theorem), but that they are somehow related w.r.t. their representations; that's the starting point of this thread.
But I still have to check the references
TrickyDicky
- 3,507
- 28
The wiki page http://en.wikipedia.org/wiki/Coleman-Mandula_theorem says the theorem only applies to Lie algebras, not to the Lie groups. So it would apply to the Poincare algebra and the local gauge symmetry, not to the Lie groups. This is consistent with the sentence dextercioby quotes from you but not with this quote from your last post.And it's strange that Poincare and gauge symmetry are unrelated as Lie groups (and cannot be related due to the Coleman-Mandula theorem), but that they are somehow related w.r.t. their representations; that's the starting point of this thread.
- 174
It applies to Lie groups as well b/c they are nothing else but exponentiated Lie algebras.
Suppose you have two Lie algebras X and Y with two sets of generators
[tex]\{X^a\}, \{X^m\}[/tex]
and defining commutators and structure constants
[tex][X^a, X^b] = if^{abc}\,X^c[/tex]
[tex][Y^m, Y^n] = ig^{mnk}\,Y^k[/tex]
The two algebras commute, i.e.
[tex][X^a, Y^m] = 0;\;\forall a,m[/tex]
This is what is required by the Coleman-Mandula theorem for a gauge Lie algebra X and the Poisson algebra Y.
Now define the Lie group elements as
[tex]U[\theta] = \exp(i\,X^a\,\theta^a)[/tex]
[tex]V[\phi] = \exp(i\,Y^m\,\phi^m)[/tex]
b/c the generators of X and Y do commute, the group elements do commute as well, i.e.
[tex]U[\theta]\,V[\phi] = V[\phi]\,U[\theta];\;\forall \theta^a,\phi^m[/tex]
- 4,244
Going from Lie algebras to Lie groups goes in this way only for symmetry groups (such as the universal cover of ISO(1,3) or the gauge groups SU(2) and SU(3)) which are simply connected.
TrickyDicky
- 3,507
- 28
dextercioby said:Going from Lie algebras to Lie groups goes in this way only for symmetry groups (such as the universal cover of ISO(1,3) and or the gauge groups SU(2) and SU(3)) which are simply connected.
That' is my understanding too, that the exponentiation procedure to go from Lie algebra to Lie group doesn't apply in general, only in special cases due to the symmetry or in the flat case where one can identify the tangent space of a manifold with the manifold itself.
- 174
Afaik it applies to each component.TrickyDicky said:That' is my understanding too, that the exponentiation procedure to go from Lie algebra to Lie group doesn't apply in general, only in special cases due to the symmetry or in the flat case where one can identify the tangent space of a manifold with the manifold itself.
What I wanted to show is that two commuting Lie algebras introduce two commuting Lie groups; this holds for all components of the Poincare group b/c you can write all group elements as matrices
[tex]X^a_i = S_i\,X^a\,T_i[/tex]
or something like that; here i labels the connected components with i=0 containing the identity
TrickyDicky
- 3,507
- 28
tom.stoer said:What I wanted to show is that two commuting Lie algebras introduce two commuting Lie groups; this holds for all components of the Poincare group b/c you can write all group elements as matrices
In this case it does seem to work out.
- 1,006
Although the mass zero representations involve some gauge transformations, I got the impression that the gauge transformations are path independent with base space being labeled by the parameters of the Poincare group. So in fiber space, the section is still trivial.
Hence also the Coleman-Mandula theorem is not violated.
- 2,215
Precisely where does he say that? I'm thinking maybe this is an example of how the term "continuous spin" can be misleading. See Weinberg vol1, bottom of p71 and top of p72. The particular representations being discussed here are excluded for phenomenological reasons: "Massless particles are not observed to have any continuous degree of freedom like ##\theta##; [...]" -- top of p72.DrDu said:Weinberg states that the continuous spin states for m=0 can be excluded for topological reasons,
The topological thing is a distinct issue...
Having effectively excluded any nontrivial action by the two translation-like generators of ISO(2), we are left with ##J_3##. (See Weinberg's eq(2.5.39) and discussion following.) To recover the usual restriction to integer or half-integer spins for massless particles, when we have only ##J_3## to work with (and the usual algebraic proof does not go through), he uses a topological argument later in ch2 -- see top of p90.ie. a 4π rotation can be transformed along a continuous path into a 0 rotation whence only integer or non-integer spins are possible.
- 2,215
Y. S. Kim and collaborators also advocated that line, but never (afaik) explained how those transformations applied to the massless ##A_\mu## field are also required (by Poincare analysis alone) to act as local phase factors on the massive electron field. I think this is a serious flaw/omission.DrDu said:[...] and gauge transformations as ghosts of rotations/ boosts around axes perpendicular to p. [...]
- 2,215
Since Poincare transformations are physically implementable, but gauge transformations are not, I actually find it comforting that the C-M thm says what it does. :-)tom.stoer said:And it's strange that Poincare and gauge symmetry are unrelated as Lie groups (and cannot be related due to the Coleman-Mandula theorem), [...]
- 2,215
Poincare symmetry is really only constraining the form of the interaction. Cf. the usual "instant form" of dynamics -- we wish to construct interacting representations of the Poincare group, but later find that in general they are unitarily inequivalent to the free representations. Perhaps this is not surprising, since the interacting theory typically admits a different/larger dynamical group than applies to the free theory. Also, the C-M thm does not exclude transformations which map between inequivalent representations, but afaik this possibility has not been explored by anyone, at least not to the point of constructing a satisfactory theory.tom.stoer said:[...] and why Casimir operators of Poincare symmetry tell something about the construction of gauge symmetries.
- 1,006
strangerep said:Y. S. Kim and collaborators also advocated that line, but never explain how those transformations applied to the massless ##A_\mu## field also are also required (by Poincare analysis alone) to act a local phase factors of the massive electron field. I think this is a serious flaw, or at least a notable omission.
Yes, Kim has published a lot of articles on that topic. But maybe it is noteworthy that one of his collaborators has been Wigner himself, e.g.:
http://www.ysfine.com/yspapers/stg.pdf
As far as the transformation properties of the electron are concerned, I don't think there is a problem. Evidently the electronic wave function may be multiplied by an arbitrary phase factor as long as it is path independent, i.e. only depends on the parameters of the total Poincare transform.
- 1,006
strangerep said:Since Poincare transformations are physically implementable, but gauge transformations are not, I actually find it comforting that the C-M thm says what it does. :-)
Btw this is not the case in Galilean relativity. There is a combination of translations, boosts time reversal which is equivalent to identity in Galilean group but generates a phase factor proportional to mass in the extended Galilean group. This leads to mass superselection in Galilean relativity.
- 2,215
I know, but it still doesn't address my objection, no matter who the authors are. :-)DrDu said:[...] maybe it is noteworthy that one of his collaborators has been Wigner himself, e.g.: http://www.ysfine.com/yspapers/stg.pdf
My point is that although the electronic wave function may be multiplied by such an arbitrary phase factor, this remains an arbitrary manual injection into the theory. The Poincare irrep analysis alone does not compel it, nor do the EM gauge transformations necessarily induce such a transformation on the electron -- one must write down the interacting Lagrangian to find it.As far as the transformation properties of the electron are concerned, I don't think there is a problem. Evidently the electronic wave function may be multiplied by an arbitrary phase factor as long as it is path independent, i.e. only depends on the parameters of the total Poincare transform.
- 2,215
OK, I'm not familiar with the details of that. Could you give me a reference, pls?DrDu said:Btw this is not the case in Galilean relativity. There is a combination of translations, boosts time reversal which is equivalent to identity in Galilean group but generates a phase factor proportional to mass in the extended Galilean group. This leads to mass superselection in Galilean relativity.
(BTW, are you familiar with Gerry Kaiser's approach in which the mass term in the centrally extended Galilean group arises by contraction from the Poincare group -- if one remains in an irreducible representation of the latter, i.e., preserving the ##M^2## Casimir (hence remaining on-shell) during the contraction. What you said above sounds somewhat different, though.)
- 1,006
strangerep said:My point is that although the electronic wave function may be multiplied by such an arbitrary phase factor, this remains an arbitrary manual injection into the theory. The Poincare irrep analysis alone does not compel it,
Of course, nevertheless I would not consider this a flaw of the theory.
How should a massive particle alone know that you are considering other particles to be present?
How should a massive particle alone know that you are considering other particles to be present?strangerep said:nor do the EM gauge transformations necessarily induce such a transformation on the electron -- one must write down the interacting Lagrangian to find it.
I think you have to analyze the transformation of representations containing both an electron and a photon.
