Why does 1 degree Fahrenheit temperature change equal 1 degree Celsius?
  • Thread starter alijan kk
    Degree
14 replies · 3K views · last reply
alijan kk
which of the following is correct
(a)1oC>1Fo
(b)1Fo>1oC
(c)1Fo=1oCo
F=1.8C+32
change of 1oC is greater than the change of 1oF or I can say it is warmer than change of one degree Fahrenheit.
In the book the answer is b that is 1 F>1C . Is it in any way possible ?
Chandra Prayaga said:
How did you conclude that change of 1 degree C is greater than change of 1 degree F?
because there are 100 divisions in centigrade scale and 180 divisions in Fahrenheit scale.
Can you post a picture of the problem from your book? You can use the Upload button to upload a PDF or JPEG file...
alijan kk said:
F=1.8C+32
They are not asking whether a change in 1 degree on the Celsius scale more than a 1 deg. change on the Fahrenheit scale.
The question is asking whether 1° F is warmer than 1° C.
I'm not sure that's true, but in any event, it won't give answer b.
Yeah, that's why I edited my Post #4 from saying what Mark44 said, and just asking for clarification of the question. Answer "b" doesn't seem correct, but there could be something else going on with the question...
Chestermiller said:
The question seems pretty unambiguous to me.
I guess I could be missing the obvious, and we can't give away the solution to homework on the PF, but still...
A degree C is wider than a degree F. And 1 degree C is higher on the thermometer than 1 degree F. So I'm having trouble seeing how "b" could the the solution to the problem... Can you send me a PM to help me out? Thanks! :smile:
https://images-na.ssl-images-amazon.com/images/I/61Xczv0eYTL._SX425_.jpg
Photo of a wall-mounted Temprite thermometer with a red liquid column, Fahrenheit scale on the left running from 120 down to -80 and Celsius scale on the right running from 50 down to -60.
  • Photo of a wall-mounted Temprite thermometer with a red liquid column, Fahrenheit scale on the left running from 120 down to -80 and Celsius scale on the right running from 50 down to -60.
Wait, I've got it finally!
It's asking for which is last alphabetically (higher ASCII representation)! Duh! :smile:
I'm not sure if you are looking for what ASCII represents or what the actual picture scale of the thermometer represents. You can figure by using or making a graph of F versus C, based on any points of use - like example boiling and freezing points for water. Look at the slope, how 1 unit C and 1 unit F compare. Make Sense?
Sorry, does that lead to selection (b)?
EDIT -- Wait, are you suggesting that we take the derivative with respect to the Kelvin scale? Boy, it seems like we are reaching pretty far to justify what the OP has posted so far...
EDIT -- Wait, are you suggesting that wetake the derivative with respect to the Kelvin scale? Boy, it seems like we are reaching pretty far to justify what the OP has posted so far...
My description is not so complicated. Too simple!
(a)1oC>1Fo
(b)1Fo>1oC
(c)1Fo=1oCo
F=1.8C+32
Maybe I misunderstood. Comparison of actual temperatures is asked. Try the formula, maybe?.
Choose (a), based on both using the formula, and using the picture of the F and C scales in the picture.
so 1 degree is wider than 1 fahrenheit.
