Why does √(13² - 12²) equal 5 without the square root sign?
8 replies · 3K views · last reply
OMGMathPLS
How does this work? (Also, I am very math illiterate and do not understand even the most basic terms, if you could kindly speak as you would to a child I would GREATLY appreciate it.)
sq rt sign over 13^2 - 12^2 (over both of it together)
Now the answer is 5, because
(13)(13) - (12)(12)
149-144 = 5
But what canceled out the sq rtt? We did the exponents so did that cancel it out?
Thanks for help.
  • Handwritten math on lined paper: problem 23 shows a struck-through square root of 13^2 minus 12^2, below it 149 minus 144, then 5, with 5 and 1 in boxes to the side.
Several of your steps are invalid.
1) $\sqrt{a^2 - b^2} \neq a - b$, i.e., the square root and the difference of squares do not "cancel out". For example, let $a = 5$ and $b = 4$. $a^2 - b^2 = 5^2 - 4^2 = 25 - 16 = 9$ and $\sqrt{5^2-4^2} = \sqrt{9} = 3$ whereas $4 - 3 = 1$.
2) What you wrote in the attachment was $\sqrt{13^2 - 12^2} = 13^2 - 12^2$. Where did the square root go? This is an invalid step.
3) $13^2 = 13 \times 13$ is actually $169$, not $149$. So your calculations are void.
Can you recalculate the expression now that your have been pointed out?
(13)(13) - (12)(12)
149-144 = 5
Thanks for help.
You have a mistake at your calculation.
It is $13^2=169$ instead of $149$.
Therefore, $$\sqrt{13^2-12^2}=\sqrt{169-144}=\sqrt{25}=5$$
Oh. Well I guess that explains it then. God!
Ok, so you leave the sq rt then at 25 but it's ok to put it back to 5?
Note that $25 = 5^2$. Thus, by commutativity,
$$\sqrt{25} = \sqrt{5^2} = \sqrt{5}^2 = 5$$
Since $5\cdot 5=25 \Rightarrow 5^2=25$ we have that $ \sqrt{5^2}=\sqrt{25}\Rightarrow 5=\sqrt{25}$
He was really only trying to help without giving direct answers (Blush)
Yeah, thanks for the help. It's just embarrassing. I really thought I partially figured it out. So they explained the arithmetic error and it's ok to solve it all the way to a 5 not simplify. Just a dumb mistake I made and I'm praying it won't kill me later. Thanks.
You can do this problem in this manner also
Hint: a^2-b^2 =(a+b)(a-b)
13^2-12^2=(13+12)(13-12)
=25*1
