Why does a parallelizable manifold imply zero Riemann tensor?
  • Level: Undergrad
  • Thread starter Thread starter Silviu
    Manifold
Silviu
Hello! Can someone explain to me why does a parallelizable manifold implies zero Riemann tensor? In the book I read this is mentioned but not proved. This would imply that parallel-transporting a vector would be path independent. But I am not sure how to show it. Thank you!
Parallelizable does not imply zero Riemann tensor; Parallelizable implies that it is possible to define a connection such that the resulting Riemann tensor is zero.
Look at what your book says again.
A closed flat Riemannian manifold can not be simply connected. A fundamental theorem says that its fundamental group must contain a subgroup isomorphic to ##Z^{n}##. So in fact, any parallizable closed manifold with a finite fundamental group e.g. ##S^3## and ##RP^3## can never be made flat.
But this is far from the whole story. For instance every orientable closed 3 manifold is parallelizable.
The fundamental group of a closed flat Riemannian manifold has a special structure.
It is an extension of an n-dimensional free abelian group by a finite group
##0→Z^{n}→π_{1}(M)→G→1##
and has no elements of finite order. For instance, for a torus ##G## is the trivial group.
- There are parallelizable flat Riemannian manifolds that are not tori. For them parallel translation of vectors around closed loops depends upon the homotopy class of the loop..
lavinia said:
Look at what you book says again.
Thank you for your reply. However I am a bit confused. I attached the part of my book that I took this from (it is from Nakahara, Geometry Topology and Physics). As far as I understand, parallelizable manifold, implies zero Riemann tensor. Could you please explain this to me a bit further (i.e. what am I reading wrong)?
I will have to think about what the book is saying.
What I said is correct. I am assuming a Levi-Civita connection and your book is not. That has to be what is going on.
The key passage is:
A vector ##V_p \in T_pM## is defined to be parallel to ##V_q \in T_qM## if ...
This defines the connection and therefore the curvature tensor. There is no a priori reason why this connection should be the Levi-Civita connection or even a metric compatible connection.
Orodruin said:
The key passage is:
Oh, I misunderstood this. So by this they mean that by parallel transporting a vector between 2 points, you keep it having the same coordinates in the respective tangent planes. I thought that this is a general property of a parallelizable manifold (i.e. independent of connection). Thank you!
