Why does Cantor's diagonal argument prove A and P(A) have different cardinality?
13 replies · 4K views
╔(σ_σ)╝
Let A be a set and let P(A) denote the set of all subsets of A. Prove that A and P(A) do not have the same cardinality
NOne
The authors proof is as follows:
Suppose there is a bijection f:A -> P(A). Let B= {x[tex]\in[/tex] A| x [tex]\notin[/tex] f(x)}. There is a y [tex]\in[/tex] A such that f(y)= B, since f is onto. If y [tex]\in[/tex] B, then by definition of B we conclude that y[tex]\notin[/tex] B. Similarly, if y [tex]\notin[/tex] B, then we conclude y [tex]\in[/tex] B. In either case we get a contraditon, therefore, no such function exist.This proof probably make a lot of sense but I can't understand it. Why define a set B that only consist of elements of A but is not elements of f(x)? Isn't f(x) supposed to be all subsets of x, which means f(x) contains x and the subsets of x? How can the set B even exist ? I'm completely lost.
Am not sure why the author provides the proof he does and I am having a hard time understanding it. But if I were to attempt it I would have given a counterexample. I know that cardinality is another word for number of elements when we are talking about finte sets.
If i formed a set A= { 1,2} I know that P(A) has subsets [tex]\oslash[/tex],{1},{2},{1,2}
Clearly they do not have the same cardinality. I am not sure if this is enough to prove the proposed statement partly because I didn't even talk about infinite sets. What do you guys think ?
No.
Since f is a function from A to P(A), f(x) must be an element of P(A). Equivalently, f(x) is a subset of A.
A priori, f(x) has no interesting properties whatsoever; it's just the result of a function applied to a value.
Hurkyl said:
No.
Okay, thanks for the clearification. But I still have a problem understading f(x). I believe it is an element of P(A) but what is its "value" ?
Suppose I have A= {1,2}
1 is an elements of A
f(1) = ? what does this even mean ?
Something about this is unsettling to me. From what I understand f is a mapping of a set to another set; why should it even work on elements of a set and not on sets themselves?
f( {1}) = {[tex]\oslash[/tex], {1}} , would make sense to me .
Can you explain a bit more, please ?
Well, there is no explicit definition given for the function, f, so it would be impossible to tell you any value. All you know is that f is a bijection, which is surjective (onto) and injective (one-to-one), and its domain and co-domain.
f is some bijection from A to P(A). i.e., for each element [tex]a \in A,[/tex] we have the element [tex]f(a) \in P(A).[/tex].
There's no one correct answer, because the mapping f has not been fully defined. Right now, we're just supposing there is SOME bijection f. But if it would make things clearer to you, consider the following mapping:
[tex]f: x \mapsto \left\{ x \right\}[/tex]
So [tex]f(1) = \left\{ 1 \right\}[/tex] and [tex]f(2) = \left\{ 2 \right\}.[/tex]
EDIT#2: I was right the first time:
No, that does not make sense. The domain of f is the elements of A and the range of f is the elements of P(A). The type of elements of A is different than the type of elements of P(A). Do you understand?
Okay if that is the case in the proof the author says :
My problem is I don't understand what's going on with the set B.
The elements of B are elements of A but are not elements of f(x). What does an element of f(x) even look like ?
╔(σ_σ)╝ said:
Okay if that is the case in the proof the author says : My problem is I don't understand what's going on with the set B.
f(x) takes an element from A and does SOMETHING to make into an element of P(A). Elements of P(A) are all subsets of A, so it looks like a subset of A.
EDIT: And, the elements of B are not elements of A. It takes its input from each member of A.
[tex]f: x \rightleftharpoons \left\{ x \right\}[/tex]
I understand this.
[/QUOTE]
I understand there is a difference, ofcourse there is. I mean A has elements like 1,2 etc but P(A) has sets as elements.
Like I said, the range of f is P(A). P(A) is the set of SUBSETS of A, i.e., the elements of P(A) are sets themselves. Thus, the elements of f(x) are sets themselves.
e.g., Let A = {1 , 2}. Then P(A) = { {}, {1}, {2}, {1, 2} }.
The point is that [tex]B \subseteq A[/tex]. Thus, we have by definition: [tex]B \in P(A).[/tex] This guarantees us a y such that f(y) = B.
No, f(x) is simply some subset of A. It doesn't have to contain x. The point is that there aren't "enough" x in order for us to "count" all the subsets of A.
If we assume that f is a bijection, then B cannot exist. This is exactly why we have a contradiction, i.e., we realize f cannot be a bijection.
Great, that makes sense!
So B= {x[tex]\in[/tex] A| x [tex]\notin[/tex] f(x)} has elements of A but x is not an element of f(x).
What does this mean ? Does this mean we get x from A but x is not in P(A) ? This make sense the elements are of different types.
Nice, this makes sense.
So basically f since f is onto we have f(y) = B if y is an element of A. I got the contradiction part of the argument but I don't see the point that "there aren't "enough" x in order for us to "count" all the subsets of A."
Basically B does not exist.
It means that for all x such that x is a member of A, you take the elements not in f(x).
EDIT: Actually, is that a typo? x can't be a member of A and not a member of f(x) because the set's elements are completely different.
Okay I just tried to piece eveything together and I think I understand now. By following the assumption that f is a bijection and the definition of B we get that B[tex]\subset[/tex] A
and B [tex]\in[/tex] P(A). Therefore, since f(y) = B, if y [tex]\in[/tex] B then y [tex]\in[/tex] f(y) which is a contradiction . Therefore, B does not exist if f is a bijection. So our assumption must be wrong.
