Why Does Density Affect the Density of its Container?
Density affects buoyancy based on the mass per unit volume of substances, which remains consistent at both macroscopic and atomic levels. When oil is placed in water or a balloon, the differing densities cause the oil to float due to the force differences acting on the fluids. The denser substance displaces the less dense one, adhering to the universal rule of fluid dynamics unless a chemical reaction occurs. At an atomic level, mass is not uniformly distributed, with denser regions, like nuclei, influencing overall behavior. Understanding these principles clarifies why substances behave differently in various containers.
Ryan Reed
I've never been able to figure this out. I can understand when you put oil in water that one floats on top of the other, but why does it still work if I put it into a balloon? Something that keeps it from directly interacting with the medium it's in?
Why should oil and water behave differently in a balloon (compared to what, a bucket)? The heavier medium feels a greater force per volume to go downwards, so energy can be released by the separation.
Sorry I didn't clarify, I meant in a atomic level, what is happening that causes buoyancy?
The force differences. It doesn't matter at which scale you look at it.
Forgetting about floating and sinking, which are macroscopic issues, the definition of density is the same on any scale.
Density = Mass per unit volume
You get the same answer if you are dealing with a bucket sized sample or a single, whole molecule. Looking inside a molecule, the Mass is not distributed uniformly so the dense bits will be the nuclei and there will be ( mostly) empty space in between occupied by some electrons.
When your substances are fluids, on the ground, the more dense substance will fall down and displace the less dense. That is a universal rule unless there is some chemical reaction between the two substances.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
