Why does F'(x-ct) equal Dy/Dx in the wave equation for a string?
makris
Assume the well known PDE of an infinite length string
D^2(y)/Dt^2 = c^2* ( D^2(y)/Dx^2)
where y=y(x,t) is the transverse displacement of the string.
D/Dx= partial derivative with respect to x
D/Dt= partial derivative with respect to t
c= velocity of the wave
According to Morse and Ingard's Theoretical Acoustics (page 97), if the shape of the string is described by the function y(x,t)=F(x-ct), then Dy/Dt= -c*F'(x-ct)= -c*Dy/Dx (Where F'(z)= the derivative of F with respect to z).
I found the last statement a little bit confusing. Could anyone explain why F'(x-ct)=Dy/Dx ? Obviously if F'(x-ct)=Dy/Dt then a constrain is put on c which is not correct...
What is \frac{\partial}{\partial x}F(x-ct)?
Does it equal F'(x-ct)?
I have concluded that Dy/Dx=F'(x-ct) after working with some examples.
So I wrote down several functions with (x-ct) as an argument and I took the partial derivative with respect to x. Then I took the derivative with respect to the argument as a whole (z=(x-ct) ) to form F'(x-ct). They are equal. Done.
Did u write everything in one line like i did?? :wink: :-p
\frac{\partial F}{\partial x}=\frac{dF(x-vt)}{d(x-vt)}\frac{\partial (x-vt)}{\partial x}=\frac{dF(x-vt)}{d(x-vt)}
Daniel.
Exactly!
I have done the same both for Dy/Dx and Dy/Dt to verify that Dy/Dt=-c*Dy/Dx
Thanks.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
