Why does Gaussian distribution approximate numerous uncertainties?
  • Context: Graduate
  • Thread starter Thread starter Niles
    Random Uncertainties
8 replies · 4K views
Niles
Hi
In http://sl-proj-bi-specification.web.cern.ch/sl-proj-bi-specification/Activities/Glossary/techglos.pdf it says that: ... if the sources of uncertainties are numerous, the Gaussian distribution is generally a good approximation.
I don't quite understand why. The Central Limit Theorem (CLT) only says that if we have a sum S of N random variables, then S will be Gaussian for very large N. So the CLT does not explain the above. In that case, where does the statement come from?Niles.
The general interpretation is that the effects of those uncertainties are additive - that's where the CLT comes in.
But that would only explain why the errors are Gaussian, not why the measured variable is Gaussian.
If the problem is a location problem, the "model" can be described as
Variable = Mean value + Random error
with "Mean value" a constant. Since the random error is Gaussian, so is the variable.
statdad said:
If the problem is a location problem, the "model" can be described as ...
I am not sure I understand what you mean by "location problem". In my case we are talking about measured speeds.
A "location problem" simply means you are trying to determine the mean value of a variable. A mean is one type of measure of location, or measure of center.
I don't know exactly what type of problem you're involved in: my posts above were
1) to show how the Gaussian distribution arises from the "many sources of uncertainty"
2) to show one way in which a measured random quantity can be assumed to have a gaussian distribution
Ok, I understand. In post #2 and #4 you use "error" and "uncertainty" interchangeably. Does
Variable = Mean value + Uncertainty
also hold for a location problem?Niles.
I guess - the main idea is that the variable is a constant value + some unmeasurable random behavior, which is often modeled by a normal (Gaussian) distribution.
An approach slightly more general than the location model is given by
Variable = Model + Error
where ``Model'' is some deterministic (non-random) expression. Consider multiple regression:
[tex] Y = \underbrace{\beta_0 + \beta_1 x_1 + \dots + \beta_p x_p}_{\text{Model}} + \varepsilon[/tex]
with [itex]\varepsilon[/itex] is the random error component
Thanks, it was very kind of you.
Best wishes,
Niles.
