A-wal
- Messages
- 186
- Reaction score
- 0
I've noticed. What does that tell you?Dmitry67 said:The example was supposed to illustrate that there is no objective 'mapping' of times in different coordinate systems. Only in nearly flat times you can use 'time dilation', which is like a low order correction. In BH you can'tuse that notion because it fails (you get infinities).
But they go past 90 degrees after the horizon, meaning anything on the inside is traveling back in time relative to anything outside.Dmitry67 said:But if you draw light cones everything is simple and logical.
I don’t see how it can ever be possible to literally reach c relative to any object, no matter how distant.Dmitry67 said:In GR, speeds (for distant objects) faster than c are well know. Just an example - areas behind the cosmological horizon.
I'm not saying GR isn't true. I'm saying that I don't think it's the whole truth. I think the equivalence principle can be taken a step further, gravity is relative, and the radius of an event horizon changes depending on how close you get to it.Dmitry67 said:That thread is quite long, please let me know: do you deny GR or do you deny some consequences of GR?
I said AT the horizon. How can a bit of it lie within range if you're already there? The horizon is equivalent to traveling at c so the observer should experience zero proper time at the horizon and negative/minus/anti proper time inside the horizon. What does that mean? Nothing. It can’t happen, just liking crossing an event horizon.PeterDonis said:Sure, you can do it at the horizon. Take a freely falling observer and pick the event on that observer's worldline where he is just crossing the horizon. Make that event the origin of the local freely falling reference frame in which the observer's "acceleration" towards the black hole disappears. Call the (local) coordinates of that frame X and T; X increases in the outgoing radial direction, and T increases in the future time direction. Then the line X = T in that frame is the event horizon--more precisely, it's the little piece of the event horizon that lies within the range of the local freely falling frame.
If you compare the time dilation/length contraction from tidal acceleration and the time dilation/length contraction from acceleration in flat space-time don’t they look the same?PeterDonis said:Which it isn't.
Why would having an inward velocity to start with make any difference? You’re treating the pull of gravity as absolute motion rather than relative.PeterDonis said:The properties of spacetime don't change depending on direction of travel. Outgoing and ingoing observers both see the same curvature of spacetime--meaning tidal gravity. They also both experience the same "acceleration due to gravity", inward towards the hole. The very fact that that "acceleration" is inward for all observers, regardless of their direction of travel, is *why* outgoing signals can't escape from any point on or inside the horizon, while ingoing signals can pass inward.
Using the river model again; you don’t feel the movement of the water because you’re in it. Tidal force is the acceleration of the water relative to the river bed?PeterDonis said:No, "acceleration" is the rate of change of *velocity*, *not* the rate of change of acceleration, which is what "tidal force" is.
Free-fall? We were talking about to different sized objects pushing against each other under (accelerating) under the influence of the "force of gravity" which you now seem to be insisting doesn't even exist anymore. You think when objects are in free-fall there is in fact no force of gravity despite the fact that they're obviously being pulled towards each other, which can even be felt slightly.PeterDonis said:No, they aren't. There is no "force of gravity". A body that is moving solely under the influence of "gravity" feels no force at all; it's weightless, in free fall.
There is no pull of gravity? The fact that freely falling world-lines move inward towards the centre of the Earth proves that there is a force at work. Without gravity they wouldn’t feel their weight. If you explain how a force works it doesn't stop being a force. You could claim the other forces don't actually exist if they were defined well enough. Stop treating gravity as if it's special. It isn't. At least it's not until you show me why rather than how it's different. Unless you can tell me something that shows how they're different in practice. The event horizon of a black hole doesn't count as practice, it's still theory.PeterDonis said:Once again, there is no "pull of gravity". It's simply that spacetime around the Earth is such that all the freely falling worldlines move inward, towards the Earth's center. You're correct that what prevents an object on the Earth's surface from following such a worldline is the fact that the object and the Earth are solid bodies; the Earth therefore pushes up on the object and keeps it from falling freely towards the center, so the object feels weight. The object also pushes down on the Earth--more precisely, it pushes down on the piece of the Earth's surface directly underneath it. But there's more Earth underneath that piece pushing back on it, and under that, and so on, so the Earth can't move inward in response to the object's push; its surface stays the same.
PeterDonis said:You're wrong. The rock will never be crushed under its own weight; it and the Moon can sit there in equilibrium indefinitely.
That would mean the energy tied up in matter becomes infinite if it has an infinite lifespan. I’m not really at all even close to anything resembling sure about this. It seems to me that objects have to do work just to remain solid objects and to produce gravity, and the energy that allows this obviously can’t last forever. I'm sure I heard somewhere that matter doesn't have an infinite lifespan?PeterDonis said:Again, you're wrong. You're basically claiming that every object will eventually collapse into a black hole, regardless of its initial state. That's wrong, and has been known to be wrong since the 1950's, when John Wheeler and some students of his studied the possible end states of matter. Kip Thorne talks about it in Black Holes and Time Warps.
But you said matter curves space-time completely differently to energy and the two processes were distinct and not equivalent? But you also said “In standard GR, curvature created by matter *is* indistinguishable from curvature generated by energy; in fact, "matter" and "energy" are really the same thing, just measured in different units, and the speed of light squared is just a conversion factor between the different units”.PeterDonis said:No, I listed four different manifestations of one cause, the stress-energy tensor. "Matter" and "energy" are just different units for expressing the stress-energy tensor; "matter-energy" vs. "pressure" and "stress" are just different components of the tensor, and how the tensor breaks up into components like that is frame-dependent; different observers in different states of motion will break up the tensor into "energy" vs. "pressure" or "stress" in different ways, but they will find the same physical laws, which depend only on the tensor as a whole, a single geometric object. It's all one cause.
I meant through tidal force. Maybe I shouldn't have said weight. You feel more tidal force the more you weigh though, so it's sort of your weight. I don’t think I’m not the one having trouble.PeterDonis said:No, you wouldn't. A freely falling object is always weightless, regardless of how curved spacetime is (how strong "gravity" is). This is one of the most basic ideas in general relativity; if you don't understand that, then it's no wonder you're having trouble with the rest of it.
Yes, and also your world-line is curved when you expend energy to accelerate because it's the same thing.PeterDonis said:Only if you mean "curved" in the frame-invariant sense I gave. In that sense, the worldline of an object "hovering" at a constant radius over a black hole is curved. So is your worldline when you are standing motionless on the surface of the Earth. If you agree with both those statements, then we're OK.
Yes you are! You keep claiming that you're not suggesting these things then go on to describe them anyway. If you're not even sure what you think then I'm not surprised you keep misinterpreting my words.PeterDonis said:I'm not insisting on any such thing.
The main thing I'm having trouble with is getting through to you. It's like having a conversation with a God worshipper. They've already made their minds up and use backwards logic from there to explain away any inconsistency that anyone raises. The only difference is you've got slightly more to work with. There is no difference between saying that space-time is curved and saying that objects paths through space-time are curved. If every object were affected by a uniform force then everything would be accelerated depending on their distance from the sources, and you could just as easily use this say that space-time is curved. If you can't get that then I'm not sure how much help you can be to me to be honest. Still, I appreciate the effort you're making.PeterDonis said:No, it isn't. Again, this (the difference between curvature of spacetime itself and curvature of a path in spacetime) is one of the most basic concepts in relativity. If you don't understand that, it's no wonder you're having trouble.
If there's no matter then there can be no space-time to separate them, and without space-time there can be nowhere for the matter to exist in the first place. A non-informal change in the amount of space between matter is called acceleration. You can use energy to do this, and matter does it as well.PeterDonis said:Not according to general relativity. In GR, spacetime is a dynamical entity of physics, right alongside matter-energy; its dynamics are contained in the Einstein Field Equation. That equation also includes matter-energy, so spacetime and matter-energy can affect each other.
And I keep on telling you that it doesn't matter. The point is that some coordinate systems show that you can reach the horizon while others that show the entire external space-time don't.PeterDonis said:And I keep on telling you that you've got this backwards, and you keep on saying it anyway. The event horizon marks the point where nothing *outgoing* can catch up with *accelerating* objects outside the horizon. It does not mean that nothing from outside can catch an object free-falling inward.
Yes, objects can experience acceleration in free-fall. It’s called tidal force. The fact that you're referring to them using different words does not make them different concepts. I haven't read a single word from you that suggests that there's any real difference.PeterDonis said:Have you not been reading all the previous posts where I explained this? Objects can experience "tidal force" in free fall. Acceleration in flat spacetime (or in curved spacetime, for that matter) means that an object is not in free fall. They're different concepts.
Oh!
