Why does if x(k) work without checking if x(k)==1?
  • Thread starter Thread starter phillyj
    Confused Loop
6 replies · 2K views
phillyj
Hi, I needed to write a function that takes a boolean vector and returns the position of the "1" values only. The correct way it was done was like this :
Code:
function res = tmp(x)
res=[ ];
for k=1:length(x)
if x(k)
    res = [res,k];
end
end
I don't understand why the "if" statement returns only the value "1"? I thought that I might have to make a boolean statement that checks if the value at "k" is equal to "1" like this "if x(k) ==1"
Please help, it's very confusing to me
the function you are trying to write is a MATLAB function already. Try
Code:
find(x)
or read the documentation from
Code:
doc find
Code:
find(x)
Code:
doc find
You misunderstand me. I know this is a built-in fuction but this was an exercise in learning MATLAB conditionals. Can you explain my original question on why the output works that way? My professor isn't around this week otherwise I might ask him.
Thanks
actually your code works fine
I did this
Code:
x = [true false true]
res = [];
for k=1:length(x)
if x(k)
res = [res,k];
end
end
and the result is res = [1,3]
I did this
Code:
res = [];
for k=1:length(x)
if x(k)
res = [res,k];
end
end
Yes, the code works. I want to know why the if statement returns only the true values. I'm still learning. When I read the code in my mind this is what I understand: From index 1 to the end of the vector, result is index. Isn't that what
Code:
if x(k)
means? This makes no sense to me. Conditionals confuse me so much. Why aren't the false elements outputted. How does MATLAB differentiate between the true and false in this statement?
"if x(k)" evaluates to true when x(k) is 1 (and possibly any other nonzero value), and evaluates to false when x(k) is 0.
This code could be written more clearly as
Code:
if x(k) == 1
  res = [res, k];
end
Ah, now I got it. It works because you should read the if clause as follows
Code:
if (value that is declared here is nonzero)
end
For example
Code:
if 5
end
always executes but
Code:
if 0
end
never executes. See "doc if" in Matlab for details.
