Why does Java give a type mismatch error when assigning int to String?
6 replies · 2K views · last reply
Niaboc67
I am programming in Eclipse and I keep seeing the error "
Type mismatch: cannot convert from int to String", not only in the example I am going to provide but other programs. I've just started programming in Java. Could someone explain to me what this error exactly means?
publicclassPracOne{
publicstaticvoidmain(String[] args){String s1 = 8;
String s2 = 8;
System.out.print(s1.equals(s2));
I rarely program in Java, but I suppose you would have to surround 8 by double quotes, on both lines. Otherwise the 8 represents an int(eger), not a string.
Please use [ code ] and [ /code ] tags as I have done below.
When you copy/pasted your code, it ended up with many spaces taken out that should be there. I have added them back in for the first couple of lines.
Java:
public class PracOne{
   public static void main(String[] args)
      String s1 = 8;
      String s2 = 8;
I agree with @Krylov. Your two String variables should be initialized with string literals, not int values. Those two lines should look like this:
Java:
String s1 = "8";
String s2 = "8";
Oh of course. Because only int can be a real number value, right? And when working with the String constructor it has to be characters or something within quotes?
Sort of. It can't have any fractional part.
Yes
Is that always true @Mark44? why does the String Constructor have to be within quotes?
Is what always true?
A String literal has to be in double quotes. That's how you know it's a string literal. A character literal (such as 'a') is in single quotes. I don't understand what you're asking about a String Constructor. Your code doesn't explicitly use a constructor for the String class.
