Why does ker(f) = {0} imply f is injective?
3 replies · 2K views
Math Amateur
MHB
I am reading "Algebra: An Approach via Module Theory" by William A. Adkins and Steven H. Weintraub ...
I am currently focused on Chapter 2: Rings ...
I need help with an aspect of the proof of Corollary 2.4 ... ...
Corollary 2.4 and its proof read as follows:View attachment 7933
In the above proof of Corollary 2.4 we read the following:
" ... ... If $$\text{Ker} (f) = \{ 0 \}$$ then $$f$$ is injective ... ... "
Can someone please explain exactly how/why $$\text{Ker} (f) = \{ 0 \}$$ implies that $$f$$ is injective ... ?
Help will be appreciated ...
Peter
Hi Peter,
If $f$ is not injective, there are distinct elements $a$ and $b$ such that $f(a)=f(b)$. Because $f$ is a homomorphism, this implies $f(a-b)=0$, and, by definition, $a-b\in\ker f$. If $a\ne b$, this gives you a non-zero element of $\ker f$.
Note that this is more generally true for any group homomorphism $f$: $\ker f$ is trivial if and only if $f$ is injective.
castor28 said:
Hi Peter,
Thanks castor28 ...
You seem to have proved the contrapositive ... but then that proves it!
Appreciate your help ...
Peter
Peter said:
Thanks castor28 ...
Peter
Hi Peter,
In fact, the converse is also true. If $f$ is injective, the equation $f(x)=0$ has no other solution than $0$, and the solution set is $\ker f$ by definition.
