Why does measuring angle from horizontal vs vertical change the Lagrangian result?
  • Thread starter Thread starter Abhishek11235
    Lagrangian Motion
9 replies · 3K views
Abhishek11235
Moved from a technical forum, so homework template missing
Q)6.10 in Morin's Classical Mechanic. All that I have to do is find Lagrangian here. After that only simple motion.
Finding Lagrangian:
Choose the coordinate system at the centre of hoop as shown in 2nd attachment. Then,I found out Lagrangian of the system. Invoking E-L Equations to find the equation of motion, I got equation like shown in 2nd attachment. After solving,I found out equillarabium point i.e ##\ddot \theta## =0. Then ,to find the motion about this point substitute $$\theta \arrow \theta_{0} +\delta$$ and I got equation like in 3rd attachment. Clearly this is not simple harmonic and I gave up.
So,I found out solution through my friend. He got simple harmonic motion by taking angle measuring from downwards vertical. So the change was just cos##\theta## appearance in third term and everything was same.
So my question: Why by choosing ##\theta## measuring from horizontal gives different result when measured from vertical?
The equation you derived is of the form ##\ddot d +Ad=B## where ##A## and ##B## are constants. Why is this not the harmonic oscillator equation? For a vertical spring-mass system the equation of motion is ##\ddot y +(k/m)y=mg##. Is the motion of a vertical spring-mass system not harmonic oscillations?
Of course, it shouldn’t. You must be making a small mistake somewhere.
You wrote ##\cos\theta = -m/M## but I’m pretty sure you meant ##\cos\theta_0 = -m/M##, for the equilibrium point, right?
Think about the equilibrium point from a Newtonian (forces) perspective, do you get the same answer?
You defined ##\theta## to be positive when it’s below the horizontal, right? (You could do it either way just be consistent.) So then does an increasing ##\theta## mean ##m## moves up or down? Does your potential energy term seem correct?
[Edit: I should’ve gone a step back; you said ##U_m = mgx_1## ... so larger x means larger potential energy? Is that right?:wink:]
Such a system oscillates, but not about y=0.
“δ” is assumed small in their equation.
One more thing... you seem to be have replaced cosθ by the approximation ##\cos(\theta _0 + \delta) \approx 1 - \theta _0\delta - \theta _0^2## ??
That is very different than the Taylor series of cosine!
The increase in ##\theta## in negative direction is taken positive. Can you spot the mistake?
I’ve already mentioned your two mistakes. One mistake is in your potential energy term (does ##U_m = mgx_1## make sense to you?) and the other mistake is your Taylor expansion of ##\cos(\theta_0 + \delta)## about ##\delta = 0##
Ok. I rectified my mistake but still I didn't get solution. Taking zero of potential at centre of hoop, let h be distance of small mass from rope. In terms of string parameters, the height ##h= c+R\theta## where c is constant. The total potential energy is:
$$U= mgh -MgRsin\theta$$
So,E-L equations give:
$$(M+m)R^2\ddot\theta =Mgrcos\theta-mgR$$
Now,this is not simple harmonic even if we expand cos using Taylor's series.
Can you provide solution by taking the origin as I have taken?
$$(M+m)R^2\ddot\theta =MgRcos\theta-mgR$$
Good! So then the equilibrium point is actually at ##\cos\theta_0 = m/M## which hopefully makes more sense! (If it was negative m/M, that would mean ##\theta_0## is greater than 90 degrees, and so tension and gravity would be in the same (tangential) direction and couldn’t cancel.)
It does give simple harmonic motion! Are you using the correct form of a Taylor series? You’ll only want the linear approximation:
$$f(x_0+\Delta x) \approx f(x_0) + \frac{df(x)}{dx}\Bigg |_{x=x_0}\Delta x$$
If you think you did this correctly then tell me how it looks for ##\cos(\theta_0 + \delta)##
Thanks for the support. I got the answer
