Why does mr = 0 in Lam's triangular ring example?
  • Level: Undergrad
  • Thread starter Math Amateur
    Example Rings
Math Amateur
MHB
I am reading T. Y. Lam's book, "A First Course in Noncommutative Rings" (Second Edition) and am currently focussed on Section 1:Basic Terminology and Examples ...
I need help with an aspect of Example 1.14 ... ...
Example 1.14 reads as follows:
Printed textbook page showing Example 1.14 on triangular rings: defines a bimodule M over rings R and S, the triangular ring A as 2x2 matrices with R, M, 0, S entries, and multiplication by formal matrix product.
Printed textbook page explaining that the ideal structure of a ring A decomposes as R, M and S with multiplication given by a 3 by 3 chart, labelled equation (1.16), and noting that R is a left ideal, S is a right ideal and M is a square-zero ideal.
I cannot follow why the results in Table 1.16 follow ...
For example, according to Table 1.16 ...
##mr = 0## for all ##m \in M## and ##r \in R## ... but why?Similarly I don't follow the other entries in the Table ...
Can someone please help ...
help will be much appreciated ...
Peter
  • Printed textbook page, Example 1.14 on triangular rings, defining bimodule M over rings R and S, the triangular ring A as 2x2 matrices, and multiplication rule (1.15).
  • Printed textbook page discussing decomposition of a ring A as R plus M plus S, with a multiplication table (1.16) whose entries are R, M, 0 in the first row and 0, 0, M and 0, 0, S in the rows below.
The ##R,M,S## in that table refer not to the original algebraic entities with those names but to isomorphs of them in ##A##.
Let's put primes on the ones in the table to avoid confusion. Then :
$$R'\triangleq \left\{\begin{pmatrix}r&0\\0&0\end{pmatrix}\ :\ r\in R\right\}$$
$$M'\triangleq \left\{\begin{pmatrix}0&m\\0&0\end{pmatrix}\ :\ m\in M\right\}$$
$$S'\triangleq \left\{\begin{pmatrix}0&0\\0&s\end{pmatrix}\ :\ s\in S\right\}$$
If you replace the ##R,M,S## in the table and its column and row labels by their primed versions, and do the matrix multiplications, you will see that the table works.
The trick is the words 'it is convenient to identify'. I understand why authors do identification. It can save on notation. But for the confusion it causes, I really don't think it's worth it. Anyway, keep an eye out for that deadly word 'identify' and its derivatives. At least this author admitted that he did it. Sometimes they don't.
Thanks Andrew ... that certainly clarifies things a lot ...
I think you caution regarding "identification" is absolutely necessary ...
Will now continue to work on Lam's example ...
Thanks again,
Peter
