Why Does My Fortran 95 Program Show Random_seed(): PUT Array Too Small?
  • Context: Fortran
  • Thread starter Thread starter Apollion
    Fortran
The discussion revolves around a Fortran 95 program that generates random numbers using a Gaussian distribution. The main issue raised is an error message stating "Random_seed(): PUT array too small," which occurs during the execution of the program. Participants are exploring the cause of this error and discussing potential issues in the code related to the seed subroutine and the random number generation process.
  • One participant describes their code and the error encountered, specifically pointing to the line where the seed is set and the call to random_seed.
  • Another participant questions the logic of adding a scalar to a vector in the seed assignment, suggesting that it may be causing the issue.
  • A different participant points out that "secnds" is not a recognized Fortran function and asks for clarification on its definition.
  • There is a mention of a potential error in the main program regarding a comma in the write statement, which may not affect the execution but could lead to confusion.
  • Some participants assert that adding a scalar to a vector is legal in Fortran, countering the earlier claim about the addition being problematic.
Participants express differing views on the legality of adding a scalar to a vector in Fortran, with some asserting it is valid while others suggest it may not be appropriate in this context. The discussion remains unresolved regarding the exact cause of the "PUT array too small" error, as multiple potential issues are identified without consensus on the primary source.
Participants note that the definition of "secnds" is missing, which could lead to compilation issues. Additionally, there are unresolved questions about the proper handling of the seed array and its dimensions in relation to the random_seed function.
Apollion
Hello everone!So i am writing this code where I am producoing random numbers from a generator through a subroutine.Then I call the subroutine and pass them through a Gaussian distribution.I have problem with my seed subroutine: my program compiles but when i try to execute it complain that "Random_seed(): PUT array too small" i have no idea what does this means!
Here is my subroutine:
subroutine setSEED (seed)
implicit none
real*8:: x
integer, dimension(2), intent(inout):: seed
if (seed(1) == 0.0) &
this where
it complains --> seed = floor(1000*secnds(0.0)) +(/0, 37 /)
--> call random_seed(put=seed)
end subroutine setSEED
and my gaussian distribution :
Real*8 Function gasdev(idum)
implicit none
integer, intent(inout) :: idum
integer, save::iset
real*8:: fac,rsq,v1,v2
real*8, dimension(2) :: x
real*8, save :: gset
!data iset/0/
if (idum.lt.0) iset=0
if (iset.eq.0) then
rsq = 0.0
do while (rsq > 1.0.or.rsq==0)
call random_number(x)
v1=2.*x(1)-1
v2=2.*x(2)-1
rsq=v1**2+v2**2
end do
fac=sqrt(-2.*log(rsq)/rsq)
gset=v1*fac
gasdev=v2*fac
iset=1
else
gasdev=gset
iset=0
endif
return
end Function gasdev
...AND MY MAIN PROGRAM:
program mainprog
implicit none
real*8::angle,gasdev,number
integer::i
integer, dimension(2) :: seed = 0
open(299,FILE='gauss.dat',STATUS='REPLACE')
call setSEED(seed)
Do i=1,10,1
angle=gasdev(seed)
print*,"angle=gasdev =",angle
write(299,*),angle
end do
close(299,STATUS="KEEP")
end program mainprog
Do you guys think can help me?its so frustrating!thank you all! :)
Technology news on Phys.org
Please put [noparse]
Code:
 and
[/noparse] tags around your code. I have done that for you.
Code:
implicit none
real*8:: x
' this where
' it complains
Code:
  implicit none
  integer, save::iset
  !data iset/0/
  if (iset.eq.0) then
     rsq = 0.0
       v1=2.*x(1)-1
       v2=2.*x(2)-1
       rsq=v1**2+v2**2
     end do
     gset=v1*fac
     gasdev=v2*fac
     iset=1
  else
    gasdev=gset
    iset=0
  endif
  return
end Function gasdev
Code:
program mainprog
   implicit none
   integer::i
   call setSEED(seed)
   Do i=1,10,1
      angle=gasdev(seed)
      write(299,*),angle
   end do
What are you trying to do with this code:
Code:
In the first line, floor returns a single value, so it looks like you are trying to add a scalar to a vector - you can't do that.
</QUOTE>
Are you sure? There appear to be at least two errors in it.
It is necessary to get a clean compilation before attempting to execute
the program.
1. "secnds" is not a known Fortran name. Nor it it defined. What is it?
2. The statement:
write(299,*),angle
in the main program has a useless comma in it.
To get useful advice, you need to post ALL and EVERY error message(s).
<quote>
implicit none
real*8:: x
this where
implicit none
integer, save::iset
!data iset/0/
if (iset.eq.0) then
rsq = 0.0
v1=2.*x(1)-1
v2=2.*x(2)-1
rsq=v1**2+v2**2
end do
gset=v1*fac
gasdev=v2*fac
iset=1
else
gasdev=gset
iset=0
endif
return
end Function gasdev
program mainprog
implicit none
integer::i
call setSEED(seed)
Do i=1,10,1
angle=gasdev(seed)
write(299,*),angle
end do
</quote>
Code:
It's perfectly legal to add a scalar to a vector.
Thus,
seed = 5 + (/ 0, 37 /)
is OK too.
The problem with the line is that "secnds" has not been defined.
  • · Replies 25 ·
9K
