Why Does My Fortran Subroutine Return the Same Value?
  • Topic: Fortran
  • Thread starter Thread starter chrissi.<3
    Code Errors Fortran
7 replies · 4K views
chrissi.<3
Hii,
Having trouble with some code I am writing, where a subroutine returns the same value regardless of different variable inputs.
C Calculate Yth and Chi values. Compute sum of Chi-squared.
Subroutine Chisquared(CPREV,CHISQ)
Real TIME(17),COUNTS(17),ERROR(17),YTH(17),CHI(17)
Real A,B,LAMDA1,LAMDA2,CHISQ,CPREV
Common TIME,ERROR,COUNTS,YTH,A,B,LAMDA1,LAMDA2
CPREV=CHISQ
CPREV=0
Do K=1,17
YTH(K)=A*EXP(-LAMDA1*TIME(K))+B*EXP(-LAMDA2*TIME(K))
End Do
Do L=1,17
CHI(L)=(COUNTS(L)-YTH(L))/((ERROR(L)**2))
End Do
Do M=1,17
CPREV=CPREV+CHI(M)
End Do
Return
End
The user inputs A, B, LAMDA1 and LAMDA2 but it always returns the same value of CPREV.
Help please!
Looks like you need some basic debug. Suggest you first add a write statement in your subroutine to print out the values of A, B, LAMDA1 and LAMDA2 to confirm the values are what you expect.
Without seeing all of the code debugging this is just guessing, but the first two lines
CPREV=CHISQ
CPREV=0
look a bit strange, considering that is the only thing you do with CHISQ.
Thanks...
I've tried adding a write statement and it seems to have no problems with using the same variables (as input by the user in the main program).
I've also got rid of that line of code CPREV=CHISQ.
Still gives me the same value :confused:
I haven't done fortran coding in a while but should not the COMMON staement be:
Common TIME(17),ERROR(17),COUNTS(17),YTH(17),A,B,LAMDA1,LAMDA2
and similar to one you have in your main part of the program?
Just guessing that maybe TIME is a different variable then TIME(17)
After throughly writing each step of the calculation (for YTH, CHI and CPREV), I found that the program was unable to handle the exponential function for certain values.
So it works ok now... as long as LAMDA1 and LAMDA2 have values less than 0.01
chrissi.<3 said:
Hii,
CPREV=CHISQ
CPREV=0
Do K=1,17
End Do
Do L=1,17
End Do
Do M=1,17
CPREV=CPREV+CHI(M)
End Do
Return
End
Help please!
You need to post the entire program. This little piece needs values
passed in COMMON.
