Why Does My OpenGL Code Show a Linker Error in Dev C++?
  • Topic: C/C++
  • Thread starter Thread starter Mr Virtual
    Compiler Error
2 replies · 4K views
Mr Virtual
I am using Dev C++ compiler version 4.9.9.2
When I compiled my OpenGL code, the compiler gave the following error:
[Linker error] undefined reference to `gluPerspective@32'
ld returned 1 exit status
[Build Error] [Project1.exe] Error 1
I am taking NeHe tutorials, where a function gluPerspective() has been used. When I compiled the same code sometime back, it worked perfectly. Any idea what this error is and how to tackle it?
regards
Mr V
Try copying and pasting the code into a new workspace. That sometimes fixes linker errors.
I tried this but nothing happened. Never mind because I found out what was causing the error: the linker section of the project had a file called -lglu32 missing. On includeing this file, the program ran perfectly.
For anybody who faces a similar problem in OpenGL and is using Dev C++:
1. Go to 'Project' and click on 'Project Options'.
2. In the dialog box that opens, click on 'Parameters'. You will see the dialog box divided into three parts: Compiler, C++ Compiler, Linker. Your job is to check that the linker category contains all the three files: -lopengl32 -lglaux32 -lglu32, written in any order. Click OK, and try to recompile and run the program. It should work fine now.
regards
Mr V
