Why does substituting t=f(x) into y=f(t) solve this system?
2 replies · 2K views
greg_rack
A point ##P## describes, in a xy plane, the geometric place identified by this parametric system
$$\left\{\begin{matrix}
x=2t-3\\
y=\frac{1}{2}t^2-4t+2
\end{matrix}\right.$$
determine the cartesian equation ##f(x,y)=0## of the geometric place
none
Hi guys, I managed to solve this problem just by "rewriting" the first equation of the system as ##t=f(x)## and then substituting that in the second ##y=f(t)## equation, ending(of course) up with the sought ##f(x,y)## function.
The problem here is I didn't really understand what I have done and why, nor the analytical reasons for that, and I'd appreciate it if you could give me the grounding I'm missing on this type of problem :)
The relationship between x and t is 1-1, so either variable can be used as a parameter for y. You changed the parameter of y from t to x. That put the line in the x,y plane and removed the t parameter. That left you with the equation, ##(1/8)(x+3)^2 - 2(x+3)+2-y = 0## as the problem requested.
greg_rack said:
Homework Statement:: A point ##P## describes, in a xy plane, the geometric place identified by this parametric system
x=2t-3\\
Relevant Equations:: none
@FactChecker gave you a good explanation.
In addition to that, it should be mentioned that it's bad practice to use the same symbol, in this case, ##f##, for three different functions.
You were given ##x## as a function of ##t##. You could say, ##x=u(t)##. Then as @FactChecker points out, you can solve that for ##t##, because ##u## is a 1 to 1 function. This gives ##t=g(x)##. Note that ##g## is the inverse function of function ##u##.
Similarly, you were also given ##y## as a function of ##t##. You could say ##y=v(t)##.
One way of combining those gives ##y=v(g(x))##.
Post #2 shows a possible result for ##f(x,y)##.
