Why does summing 1/(i(i+1)) give 1.899999976 instead of 1.9?
  • Topic:
  • Thread starter Thread starter mathmari
    Sum
36 replies · 8K views
I found the abolute value of (pi^2)/6-the result(for forward method:1.6439348459243774,for backward method:1.6439344882965088).
Right.
So apparently the forward method gives a result that is higher in this case than the backward result.
However, the true result that we should have for n=1000 is best approximated by the double backward algorithm, which you already gave.
Code:
float forward   = 1.6439348459243774
float backward  = 1.6439344882965088
double backward = 1.6439345666815597
As you can see the "float backward" result is closer to the double result than the "float forward" result.
However, we do see that the "float forward" result is higher than the "float backward" result.
This would happen due to rounding errors that work out differently.
So,isn't the error of the backward method bigger for n<=1000??
The difference with $\frac{\pi^2}6$ of the backward method is bigger in this case (presumably due to "bad" rounding in the forward method that turns out to be "lucky").
However, the error in the backward result is smaller, since the result is not supposed to be $\frac{\pi^2}6$. It needs many more iterations before it gets there.
If you multiply your result with 6 and find the square root and then the error,how could we explain why the forward method gives better results for smaller n?? :o:confused:
Lucky bad rounding.
Suppose we do the calculation with 2 significant decimal digits for n=4.
Then we get:
forward: ((1+0.25)+0.11)+0.063 = 1.5
backward: 1+(0.25+(0.11+0.063)) = 1.4
As you can see, the forward result is closer to $\pi^2/6 \approx 1.64$.
That is because of the lucky bad rounding of 0.25 to 0.3 and of 0.063 to 0.1.
Note that after iteration n=4, the forward result does not increase anymore (the next term is 0.04). But the backward result keeps getting closer to the desired end result.
