Why Does Telluric Acid Not Follow the Expected Pattern?
  • Thread starter Thread starter END
    Acid General
4 replies · 4K views · last reply
END
According to Wikipedia, the proper chemical formula for Telluric Acid is [itex]Te(OH)_6[/itex].
From what I've learned in chemistry thus far, acids made from polyatomic ions within the same group follow a similar pattern. For example, Selenic Acid [itex]H_2SeO_4[/itex] is analogous to Sulphuric acid [itex]H_2SO_4[/itex]. If this is the case, why is it that Telluric Acid differs from this pattern? I would expect its chemical formula to be [itex]H_2TeO_4[/itex], but apparently this represents Metatelluric acid which is the analogue of sulfuric acid and "is unknown." (Wikipedia)
Why is this the case?
Thank you!
Chemistry news on Phys.org
from http://tellurium.atomistry.com/telluric_acids.html
Tellurium trioxide gives rise to several hydration products which can all be regarded as telluric acids, but which are more conveniently considered as products of the further hydration of telluric acid, H2TeO4, the compound H2TeO4.2H2O (possibly an "ortho-" telluric acid, H6TeO6) being the most stable.
H2TeO4.2H2O can be written as Te(OH)6 making the water of hydration look like hydroxyl groups.
Thanks, Jim.
So would ##H_2TeO_4\cdot2H_2O## then be considered a hydrate due to the presence of water molecules within it?
In addition, how are we supposed to know that telluric acid is a hydrate? (i.e., that it has a ##nH_2O##)
I feel like you are trying to describe reality with simplified formulas, which won't work.
Hydrates often have well defined water molecules in the crystal lattice (and I believe that's the way you are trying to picture the telluric acid). But that's not the case here. We call observed substances "hydrates" because they differ by a water molecule, but they are actually different (although related) compounds. This is quite common - similar thing happens for example with sodium bisulfite and sodium metabisulfite.
In Group IV, carbonic acid is [itex]H_2CO_3[/itex], but silicic acid is [itex]H_4SiO_4[/itex] - metasilicic acid [itex]H_2SiO_3[/itex] is polymeric.
In Group V, nitric acid is [itex]HNO_3[/itex], but phosphoric acid is [itex]H_3PO_4[/itex] - metaphosphoric acid [itex]HPO_3[/itex] is polymeric.
The reason both cases being that the bigger central atom prefers bonding to more oxygens.
Same reasoning applies to tellurium and iodine - [itex]Te(OH)_6[/itex] has Te bonded to 6 equal oxygens, whereas metatelluric acids are polymeric structures where some oxygens are bonded to two tellurium atoms.
