Why does the dot product in this solution equal zero?
Darkmisc
Prove that the medians bisecting the equal sides of an isosceles triangle are equal.
a · b = |a| × |b| × cos(θ)
a · b = ax × bx + ay × by
Hi everyone
I have the solutions for the problem. It makes sense except for one particular step.
Why does the dot product of a and b equal zero? I thought this would only be the case if a and b were at right angles to each other. The solutions seem to be a general proof and should work for all isosceles triangles (not just right angle triangles).
The solution would still make sense even if a · b didn't equal zero. Why does it equal zero here?
Thanks
Diagram of isosceles triangle OAB with O at the apex, A and B at the base, and midpoints N on OA and M on OB; arrows drawn from A to M and from B to N cross inside the triangle.
Handwritten-style vector derivation: AM = AO + 1/2 OB = -a + 1/2 b; BN = BO + 1/2 OA = -b + 1/2 a; then |AM|^2 and |BN|^2 expanded as dot products, ending with |a|^2 + 1/4|b|^2 and 1/4|a|^2 + |b|^2, and the note that |a| = |b| so |BN| = |AM|.
Darkmisc said:
Homework Statement:: Prove that the medians bisecting the equal sides of an isosceles triangle are equal.
Relevant Equations:: a · b = |a| × |b| × cos(θ)
Hi everyone
Thanks
I don't think you need a b = 0 for the proof to work.
Edit: Now I just saw that you wrote just that.
Maybe they just forgot the missing terms.
Hi everyone
Thanks
I'll echo Philip Koeck above, it does not matter if ##a \cdot b = 0##. As you can see, if |a| = |b| then
##a \cdot a - a \cdot b + \dfrac{1}{4} b \cdot b = \dfrac{1}{4} a \cdot a - a \cdot b + b \cdot b##
whether ##a \cdot b = 0## or not. But (never trust a diagram!) it almost looks like the diagram has a and b perpendicular. It seems that this is the whole problem statement but is there somewhere that says a and b are perpendicular?
-Dan
-Dan
No, it wasn't specified that a and b are perpendicular. I also think Philip Koeck was right about them forgetting to delete a · b.
There was a previous problem in which a and b were perpendicular. Maybe that's what caused the authors to mistakenly say that a · b = 0 in the present problem.
