Why Does the Limit of (n! / n^2) Approach Infinity?
  • Thread starter Thread starter ThatDude
    Confused Limit
The discussion revolves around the limit of the expression (n! / n^2) as n approaches infinity, a topic within the realm of series and factorial functions. Participants are examining the behavior of this limit and its implications in the context of a series problem.
  • Participants are questioning the reasoning behind the limit approaching infinity, with one suggesting that the terms in the numerator are decreasing while the denominator remains constant. Others propose examining specific values of n to clarify the misunderstanding.
Multiple interpretations of the limit are being explored, with some participants suggesting the use of Stirling's approximation as a potential approach. There is an ongoing examination of the factorial function's properties and how they relate to the limit in question.
Some participants note that the original poster may be misinterpreting the behavior of the terms in the numerator and denominator, indicating a need for further clarification on factorial growth compared to polynomial growth.
ThatDude
So, I'm doing a series problem, and after applying the root test I end up with the following limit:
Lim as n--> inf of (n! / n^2) = infinity according to the solution manual.
I can't seem to understand this because the way I look at it, each term in the numerator is getting smaller [ (n)(n-1)(n-2)..] but each term in the denominator is staying constant as n^2. So shouldn't the limit equal zero?
Google 'properties of factorial function' for example. You will see exactly what is going on for large n.
For [itex]n \geq 3[/itex] we have
[tex] \frac{n!}{n^2} \geq \frac{n(n-1)(n-2)}{n^2} = n - 3 + \frac{2}{n}.[/tex] The inequality follows from the fact that if [itex]n = 3[/itex] then [itex]n! = n(n-1)(n-2)[/itex] whilst if [itex]n \geq 4[/itex] then [itex](n-3) \times \dots \times 1 \geq 1[/itex].
I recommand stirling approximation, it will be very appropriate for this case, it states that when n goes to infinity n! = √(2πn) * (n/e)^n, so try it !
You're looking at the wrong end in the numerator. Look at the n=3, n=4, and n=5 terms, for example. You have
\begin{align*}
\frac{3!}{3^2} &= \frac{3\cdot 2\cdot 1}{3\cdot 3} \\
\frac{4!}{4^2} &= \frac{4 \cdot 3\cdot 2\cdot 1}{4 \cdot 4} \\
\frac{5!}{5^2} &= \frac{5\cdot 4 \cdot 3\cdot 2\cdot 1}{5 \cdot 5}
\end{align*} Can you see the mistake in your reasoning?
So let's say I have the sequence n!(2^n) /(2n)!, how would I show that this converges to zero.
Start by expanding the (2n)! in the denominator to (2n)(2n -1) ...(n+1)(n!).
  • · Replies 24 ·
  • · Replies 20 ·
  • · Replies 23 ·
