Why Does the mth Interference Maximum Vanish in Single Slit Diffraction?
3 replies · 6K views
slyman
Two narrow slits of width a are separated by center-to-center distance d. Suppose that the ratio of d to a is an integer d/a=m.
Show that in the diffraction patterns produced by this arrangement of slits, the mth interference maximum (corresponding to dsin(theta)=m[tex]\lambda[/tex]) is suppressed because of coincidence with a diffraction minimum. Show that this is also true for the 2mth, 3mth, etc., interference maxima.
My attempt dsin(theta)=m[tex]\lambda[/tex] indicates the conditions for interference maxima, where d is the distance between the two slits. We know that diffraction minimum occurs when a*sin(theta)=[tex]\lambda[/tex], where a is the slit width. Divide by both equations and we can determine which interference maximum coincides with the first diffraction minimum: d/a=mI don't really understand what the question wants. Could someone please help me out? Thanks in advance.
Please read the posting guidelines and use the template provided. We can not help you unless you first show some effort yourself.
Okay, you've almost answered the first part of the question, but you've gone about it backwards.
Let [itex]d\cdot sin\theta = m \lambda[/itex] and [itex]d/a=m[/itex], then you can show that [itex]a \cdot sin \theta = (d/m)sin \theta =...[/itex]..which answers the first part of the question.
For the second part, how would you proceed?
