Why does the Poisson distribution apply here?
The discussion revolves around the application of the Poisson distribution in modeling the number of bacteria in a bacterial solution, particularly in the context of counting colonies in Petri dishes. Participants explore the conditions under which the Poisson distribution is appropriate and the implications of incubation time on the distribution.
  • One participant questions why the number of bacteria is modeled as Poisson distributed with parameter theta, suggesting that the rate of multiplication and incubation time should influence the distribution.
  • Another participant asserts that the counting refers to bacteria colonies, which arise from single bacteria, and proposes that the number of bacteria in each sample follows a binomial distribution, with Poisson as an approximation when many bacteria are present.
  • Further inquiry is made into the binomial distribution's parameters, specifically what constitutes n and p in this context.
  • A participant explains that the incubation time is not significant for the distribution, as it primarily allows colonies to grow large enough for counting, emphasizing that the bacteria density in the original solution is the focus.
  • Another contribution clarifies that the Poisson approximation arises from the probability of finding a bacterium in an infinitesimal volume, under the assumption of even dispersion of bacteria in the fluid.
  • One participant mentions that the Poisson distribution can still apply even if the mean density is non-constant, indicating that the parameter can be derived from the integral of the mean density over the region.
Participants express differing views on the appropriateness of the Poisson distribution versus the binomial distribution, and there is no consensus on the impact of incubation time on the distribution. The discussion remains unresolved regarding the best model to apply in this scenario.
Some assumptions about the distribution of bacteria and the effects of incubation time are not fully explored, and the discussion highlights the complexity of modeling biological processes with statistical distributions.
nonequilibrium
Hello,
I'm reading a text about statistics, but I don't understand why Poisson applies. (Note, this is not an assignment or anything like that.)
One disposes of a bacterial solution for which one would like to know the density (i.e. the number of bacteria per unit volume). [...] One takes five Petri dishes and fills each Petri dish with 1 ml of the bacterial solution. After a certain incubation time one starts 'counting' the number of bacteria in each of the Petri dishes. [...] In this example we in fact have the situation of a Poisson distribution for which we have (a realization of) a sample of size 5, X_1, \cdots, X_5. The parameter \theta is here the mean density of bacteria per ml solution.
Why would X be Poisson distributed with that parameter theta?
The only Poisson that I could find reasonable is modelling X as Poisson distributed with parameter \lambda t where \lambda is the rate of multiplication (of the bacteria), and t is the incubation time (which is mentioned in the quote, but strangely enough does not affect the probability distribution in the above case).
Can someone give me their take on the matter?
The 'counting' refers to the number of bacteria colonies in each petri dish, with each colony presumed to have arisen from a single bacterium. The number of bacteria in each 1 ml sample actually has a binomial distribution, but if there are many bacteria present, a Poisson distribution is a good approximation.
Thanks for posting.
In what sense is it binomially distributed? What is n and what is p?
And the quote above mentions an incubation time. Shouldn't the distribution account for this time? I.e. shouldn't the incubation time have an effect on the distribution?
A Poisson process is memoryless and is characterized by a fixed rate parameter such as a half-life or doubling time. Many natural processes obey this model at least for parts of a process. Bacterial populations tend to increase at a fixed rate unless or until some limiting factors (ie food supply) kick in.
http://mathworld.wolfram.com/PoissonProcess.html
mr. vodka said:
Thanks for posting.
There are a discrete number of bacteria in each 1 ml sample. The probability of finding 0, 1, 2 ... bacteria in any given sample has a binomial distribution. n is the total number of bacteria present in the solution, and taking 5 samples allows one to estimate p and thereby estimate the bacteria density. Since there are a large number of bacteria, one can use a Poisson distribution as a surrogate.
The incubation time is immaterial -- it's there only to allow the colonies enough time to grow large enough to be seen and counted. In this type of experiment, one generally expects to see a few to a few dozen colonies, each a couple of millimeters in size, and each presumed to have grown from a single bacterium. Keep in mind that it's the bacteria density in the orginal solution that is of interest.
You start with N bacteria in a volume V of fluid.
So the probability of finding 1 bacterium in an infinitesimal fluid volume dv is (N/V)dv.
That's where the Poisson distribution approximation comes from. It is an approximation, because it assumes the bacteria are geometrical points and they are dispersed "evenly" through the fluid, so that a small enough volume dv will never contain more than one bacterium - i.e. the geometrical distribution of bacteria in the fluid doesn't contain any limit points.
Thank you, I think I understand now!
The Poisson distribution holds even if the mean density is non-constant (but still deterministic) - the Poisson parameter here will be the integral of the mean density over the region.
