Why Does the Set {1/n : n ∈ ℕ} Have an Empty Interior?
4 replies · 5K views
zigzagdoom
Hi All,
A simple question but one for which I cannot seem to get the intuition.
1. Homework Statement
Find the interior point of {1/n : n ∈ ℕ}.
N/A
Let S = {1/n : n ∈ ℕ}, where S ⊆ℝ
x is an interior point if ∃N(x ; ε), N(x ; ε) ⊆ S.
My answer: IntS = (0,1)
But apparently the answer is ∅, which I do not seem to get.
Would it be that a small epsilon neighbourhood of x contains some element y such that y is not an element of S?
Any help is appreciated.
Edit:
I seemed to have figured it out. For every x for which we try to find the neighbourhood for, any ε > 0 we will have an interval containing irrational numbers which will not be an element of S.
Thanks
I assume that ##N(x;\varepsilon)## is the open ball of radius ##\varepsilon > 0## centered at ##x##?
Note that your answer could not possibly be correct, because for any set ##S##, in any topological space, it holds that ##\text{int}\,S \subseteq S##.
Yes indeed. Try to make this precise. Take an arbitrary ##x = \frac{1}{n} \in S## and an arbitrary ##\varepsilon > 0##. Now indentify an element ##y \in \mathbb{R}## such that ##|x - y| < \varepsilon## but ##y \not\in S##. (You can write down an expression for such ##y## explicitly in terms of ##x## and ##\varepsilon##.)
zigzagdoom said:
Edit:
Yes, well done!
Maybe it's also nice to know that a set ##A## in a topological space is called discrete when every point ##x \in A## has a neighborhood intersecting ##A## only in ##\{x\}##. So, ##S## is an example of a discrete set. However, there are sets (also in ##\mathbb{R}## with the usual metric) with empty interior that are not discrete. (And you know them, too, of course.)
Thanks a lot Krylov.
N(x; ε) is indeed the ball centre x, radius ε in this notation.
- (0,1) cannot be an interior point as 0 is actually a boundary point (i.e. ∀ N(0 ; ε), N(0 ; ε) ∧ ℝ \ S ≠ ∅)
- Let x ∈ S and x = 1/n. Now take any neighbourgood of x, N(x ; ε) = {y ∈ ℝ : |x - y| < ε}.
But for any n ∈ ℕ and any φ>0, there exists an irrational number i ∈ ℝ \ S, such that n - φ < i < n.
But then in any neighbourhood of x = 1/n, there exists a number 1/i. But 1/i ∉ S. Therefore there is no interior points of S, and IntS = ∅.
Krylov said:
Yes, well done!
Thanks!
