- 1
Hello, I want to make some rust (iron oxide, Fe2O3), and I know there are many ways of going about this, but I would like to be able to get a significant quantity and be able to use it within a short period of time.
Here are the 4 methods I have tried:
-electrolysis, putting a piece of iron on the annode and letting it corrode, but this takes a long time to get it out of the water and it isn't very pure
-the old fashion was of putting an iron nail in salt water, but this takes a while to get any usefull amount
-next I tried putting some very thin steel wool into water (with and without salt), I am most pleased with this method because it seems to rust rather quickly and I don't need that much water to do it with, it won't take as long to evaporate off the water and get the rust, but it still takes too long to do that
-I know that if you "burn" steel wool, you are oxidizing the iron and making rust, well this is fast, and it should produce lots of rust, but when I trie it, it does produce a rather entertaining show with some sparks, but when it is over, all I have is a darker, more britter version of what I started with, I don't "see" any rust, but isn't that what it is suppose to produce?
if I could get this method to work, it would be my most preferable, it is the fastest and easiest in producing the most rust, but I can't seem to get the rust I am making, how can I do this? is it becase that even though the iron is reacting to make the rust, the other elements in the "Steel" wool are keeping it from being gotten some how?
any other fast mean of making the rust would work to, but I would still like to learn what the problem is with the steel wool method aswell.
thanks
thanks
