Why doesn't upthrust increase when a solid is pushed deeper in liquid?
  • Thread starter Thread starter Suraj M
    Buoyancy Upthrust
8 replies · 2K views
Suraj M
A solid is completely immersed in a liquid. The force exerted by the liquid on the solid will(more than one right)
(a)increase if it is pushed deeper inside the liquid.
(b)change if its orientation is changed
(c)decrease if it is taken partially out of the liquid
(d)be in the vertically upward direction
U=Vdlg
Option C and D are true i got that, and the answers also say that the answer is C and D.
But why is Option A not true, the upthrust does increase when the solid is pushed down, right??
I just want to be sure. Thank you in advance
How do you propose that the force should increase?
With depth there would be increase in pressure, as liquids have a higher compressibility factor than solids. Hence the density of the liquid would increase at a higher rate as compared to the solid. So the upthrust should increase, right?
Is this statement true for all possible liquid-solid pairs?
I'm not sure. By you're tone, i guess it isn't true for all.
Could you give an example of a pair where this wouldn't be true‽
Mercury ( ~ 3 ppm/atm) and let's say hard rubber.
wouldn't rubber float in mercury?
You could be using rubber coated uranium bricks; you're not constrained by liquid and solid densities in any way in the problem statement, you're merely calculating net buoyancy forces.
oh ok. thank you!
