Why don't stars explode? What holds them together?
  • Level: Undergrad
  • Thread starter alancj
    Stars
32 replies · 16K views · last reply
rocketman7 said:
stars are in a state of hydrostatic equallibrium. outward radiative pressure from photons and nuetrinos emitted in he core are balanced by the inward force of gravity.:smile:
So are we stating that the inward force of gravity, squeeze's photons out from the inner core, similar, like a "wet sponge" expelling water when squeezed, so to speak?
Photons are only the dominant source of pressure in stars much more massive than the sun. In most stars, it is the particles themselves that are doing the pushing, not the photons (and certainly not the neutrinos).
While this is technically true, as SpaceTiger pointed out, radiation pressure is insignificant in the case of the sun.
I whipped this up in Matlab real quick to demonstrate. The graph is on a log scale, so the [tex]10^#[/tex] you see on the y-axis is the same as that part in scientific notation. it had to be log scale for the gas pressure to even be noticeable on the graph. A difference of 10^4 is a factor of 10,000 difference between the two.
  • Log-scale line graph titled Prad and Pg, Pressure (Pa) against Radius (cm) times 10^10, with Prad (blue) falling from about 10^6 to about 10^2 and Pg (green) falling from about 10^10 to about 10^5.
