Why Geodetic Equation Doesn't Accept Schwarzschild Solutions
27 replies · 3K views · last reply
jk22
In the Schwarzschild metric case why is : $$r=cste,$$
$$\theta(t)=\arccos(\sin\alpha\cos\omega t)),$$
$$\phi(t)=\arctan(\tan(\omega t)/\cos\alpha),$$
$$t=\tau$$
not solution to the geodetic equation ?
What path are you trying to describe? By ##r=cste##, do you mean ##r## is constant? A verbal description of what you are trying to do is needed because the answer to your question as written is "because that path is not a geodesic".
One obvious issue is that ##t=\tau## is not possible for finite ##r##, assuming that ##\tau## is supposed to be the proper time on the geodesic. If you simply intended to rescale your time unit then that has implications for the modulus of your four velocity and hence the form of your geodesic equations.
I supposed a circle was a solution so that time flows equally, that's my mistake
I supposed the equation is scale invariant and I got ##\ddot{t}=0## I'll look again
What "geodesic equation" (I assume that's what you mean) are you trying to solve? Please write it down explicitly or give a reference. There isn't just one of them.
I wanted to solve ##\frac{d^2x^\mu}{d\tau^2}=-\Gamma^\mu_{\alpha\beta}\frac{dx^\alpha}{d\tau}\frac{dx^\beta}{d\tau}##
The solution I wanted to check is a circular uniform motion, it is a solution if ##\theta=\pi/2## but if the circle is rotated by an angle ##\alpha## around the y-axis I got that it is no more a solution. Maybe I made a calculus mistake, but if not the question is :
Is the Schwarzschild metric spherically symmetric, or should one use isotropic coordinates to have this rotated circular trajectory a solution ?
Do you mean a free-fall circular orbit? That will only be a solution to the geodesic equation for particular combinations of parameters; not all circular motion in Schwarzschild spacetime is free-fall geodesic motion.
Yes.
Whether a particular worldline is a geodesic is independent of any choice of coordinates.
The simplest approach is to show by symmetry arguments that motion stays in a plane and then take that plane to be defined by ##\theta = \frac \pi 2##. Otherwise, the more general solution gets unnecessarily complicated.
What you mean by that? Even the most general solution is simple in the case of the sphere.
The equations are messier, especially for trans-polar orbits that go through the ##\theta## coordinate singularities. And unnecessarily so, since you can just solve for equatorial orbits and then rotate coordinates.
It could be done the reverse way too : if it were spherically symmetric, rotate the circular uniform motion and see if it is solution of the equation of motion, which is quite simple todo with a CAS for example.
At least in the Newtonian case the OP relations are a solution.
So I was asking myself if the EFE were symmetric but not the geodesic equation ?
What do you mean by "symmetric"? How would the geodesic equation be symmetric or not symmetric?
By symmetric I mean the symmetry of the problem. Here it is a spherical one. So we ahould normally perform any rotation the problem should remain the same. We can check the circular uniform motion is a solution of the geodesic equation at ##\theta=\pi/2## but the same motion seen by another rotated non moving observer is not.
So is it correct to deduce that either the equation shall be recomputed in the rotated coordinates,
Or the background spacetime given by the EFE is absolute and hence there were preferred directions ?
The symmetry of the problem obviously applies to all equations involved in the problem, so it would apply equally to the solution of the EFE and to the geodesic equation.
jk22 said:
We can check the circular uniform motion is a solution of the geodesic equation at but the same motion seen by another rotated non moving observer is not.
No. Circular uniform motion with the appropriate orbital parameters (angular velocity matched up correctly with radial coordinate) is always a solution of the geodesic equation. It's just mathematically much harder to demonstrate this if you insist on choosing the coordinates so the circular orbit is not in the ##\theta = \pi / 2## plane. But you don't have to go to all that trouble precisely because of the spherical symmetry: you can always choose the coordinates so the circular orbit you are interested in is in the ##\theta = \pi / 2## plane, so demonstrating that the orbit solves the geodesic equation for that special case is demonstrating it for any circular orbit whatever that has appropriate orbital parameters.
Obviously if you change the coordinates you have to recompute everything that depends on the coordinates. That includes the particular terms and numerical factors that appear in the geodesic equation.
This was just for verification of the symmetry.
Can This argument of letting ##\theta=\pi/2## also be done to ##\phi=0##, giving a free fall case admitting the initial speed is zero, but r is not constant ?
If you mean, is setting ##\theta = \pi / 2## and ##\phi = 0## a valid way to treat purely radial geodesic motion, yes, it is.
...and the equations can be solved analytically.
Is The fact that the rotated circular motion is not a solution because contrary to the EFE the geodesic equation is not invariant under coordinates change ?
A rotation of any geodesic is also a geodesic in Schwarzschild spacetime (as long as we rotate in a sense that the spacetime has rotational symmetry). The point, I think, is that any old circular motion is not a geodesic. Only circular motion at orbital speed is a geodesic.
The geodesic equation is invariant under coordinate change. However, when you actually try to compute a geodesic you need to adopt a coordinate system, and the computations you make will differ. But the same is true of the EFE. For example you can write down the Schwarzschild metric in Cartesian-like ##t,x,y,z## coordinates and it does not have the same form as the familiar spherical polars version.
Is it correct to derive the geodesic equation to use a coordinates chart ##x^\mu=\xi_p^\mu(y^\nu)## and to say the x coordinate lives in a flat space whereas the y is equiped with the metric obtained from EFE.
Since x space is flat then the geodesics are straight lines in it : $$\frac{d^2 x^\mu}{d\tau^2}=\frac{d^2\xi^\mu_p}{d\tau^2}(y^\nu)=0=\frac{d}{d\tau}(\frac{\partial\xi_p^\mu}{\partial y^\alpha}\frac{d y^\alpha}{d\tau})=\frac{\partial^2\xi_p^\mu}{\partial y^\alpha\partial y^\beta}\frac{d y^\alpha}{d\tau}\frac{d y^\beta}{d\tau}+\frac{\partial\xi^\mu}{\partial y^\alpha}\frac{d^2 y^\alpha}{d\tau^2}
\Rightarrow \frac{d^2 y^\nu}{d\tau^2}=-\underbrace{\frac{\partial y^\nu}{\partial\xi^\mu}\frac{\partial^2\xi^\mu}{\partial y^\alpha\partial y^\beta}}_{-\Gamma^\nu_{\alpha\beta}}\frac{dy^\alpha}{d\tau}\frac{dy^\beta}{d\tau}$$ ?
Then ##\xi_p^\mu## is weird since it is a coordinate change that creates curvature out of flat space ?
It doesn't depend on the use of coordinates whether your space is flat or not. Curvature is represented by a tensor and thus a coordinate-independent, geometrical property of the spacetime under investigation.
@jk22 - you never write out what you are actually doing. You just throw out maths. That leaves us to guess, and also suggests strongly that you aren't writing it out because you don't understand yourself. The more you write out the more we can help.
It should be obvious that your conclusion is wrong. Quite apart from @vanhees71's comment, consider two objects in the same freefall orbits, but opposite directions. They encounter each other twice per orbit. How could two straight lines do that?
More generally your ##x^\mu## coordinates are poorly constrained. You have defined them along a particular geodesic, but that does not say anything about their behaviour off the geodesic. Your equation ##0=\frac{dx^\mu}{d\tau}## only applies along your chosen geodesic. Furthermore, ##x^\mu=\xi^\mu_p(y^\nu)## makes no sense - you have different numbers of free indices. Presumably you meant ##x^\mu=\xi^\mu_\nu(y^\nu)##.
Any circular orbit with the appropriate orbital parameters is a solution, regardless of what plane it is in or how the coordinates are rotated. But not all circular orbits have the appropriate orbital parameters. The way you find out which ones do is...by solving the geodesic equation.
No. It is. But you need to do the math correctly. Incorrect math will of course give you incorrect answers.
Yes that's the point, either x is of dimension 5 and y dimension 4, representing the embedding, or both are of dimension 4 then it was said ##\xi_p(y^\nu)## is a "local" coordinates transformation, meaning p is a point at which the function is determined but not derived. This permits to induce curvature but it's a bit sloppy. It were like writing ##f(x)=_x g(x)## and ##f'(x):=_x g'(x)##.
For example ##f(x)=_x\cos(x)## and hence ##f'(x)=-_x\sin(x)##
Does this scripture I saw in an old course of the TU Vienna make sense ?
I have absolutely no idea what you are talking about. You have not even mentioned an embedding before this post, nor that there can be different numbers of dimensions in your two spaces. You introduce new notation with what appears to be a leading subscript ##x## without explaining what it's supposed to mean, merely referring to "some old notes" to explain without providing either a link or a reference I could try to track down.
You do not address my point that geodesics in curved spaces can cross multiple times but flat space ones cannot. You have addressed my point about mismatched indices by mismatching them in a different way. Furthermore, you don't explain how an apparently index-free function ##\xi## can convert a four-index coordinate into a five-index one. Either it needs an upper and a lower index, or else you are using yet more new notation without explaining it.
  • Love
@jk22 the only comprehensible question you have asked in this thread (are solutions of the geodesic equation independent of coordinates) has been answered (yes). At this point you are not making sense despite repeated attempts. So this thread is now closed.
