Why getline() works with string but getline(dataF, str) doesn't with fstream::getline()
  • Thread starter yungman
65 replies · 11K views · last reply
yungman
I have been reviewing Chapter 12 files. From experiment,
C++:
#include <iostream>
#include <fstream>
#include <string>
using namespace std;
int main()
    char Ar[] = "demofile.txt";
    string Cwstr, Crstr;
    char cAr[100];
    int size = 100;
    fstream dataF;
    dataF.open(Ar, ios::in);
    getline(dataF, Crstr);
    //dataF.getline(Crstr, size);
    count << Crstr << "\n\n";
    dataF.close();
    return 0;
Below, when I said doesn't work, I mean VS gave me a compile error. But if I tell compiler to just run it, it seems to work.
I found if I try to read a file into string, only line13 getline(dataF, Crstr) works. line 14 dataF.getline(Crstr,size) flag error no matter how I tried.
The opposite is true if I read the file into an array, getline(dataF,Ar) flag error and only dataF.getline(Ar, sizeof(Ar)) works.
The book only talk about dataF.getline with Array, I learn getline(dataF,Crstr) here or online. Is my finding valid?
Thanks
Filip Larsen said:
I recommend you try look at the specification for the two API methods (e.g. see [1] and [2]) and see if you can explain your own observations.
[1] https://en.cppreference.com/w/cpp/string/basic_string/getline
[2] https://en.cppreference.com/w/cpp/io/basic_istream/getline
My problem is I have not study any of these, like this one, I don't understand any line of these:
cppreference documentation page for std::getline listing four template overloads, two taking a delimiter and two without, with the C++11 rvalue-stream variants marked since C++11.
That's the frustration when go online, I am sure if I study a few more months, I should be able to understand this better. I have not study class, template and all that.
Thanks anyway.
Forget about the last question, I know how it works within the context of the chapter already. I cannot stop and look into Classes, template and all that. It becomes chicken and eggs. I was hoping to get a yes or no on that only. I have a more pressing problem I cannot figure out:I am working on random files seekg. This is the program in the exercise. For the life of me, I cannot figure how this works:
C++:
//12.17 random file seekg
#include <iostream>
#include <fstream>
int main()
    char ch;
    char Cw[] = "abcdefghijklmnopqrstuvwxyz";
    fstream file;
    file.open("letters.txt", ios::out);
    file << Cw;
    file.close();
    file.open("letters.txt", ios::in);
//Move to byte 5 from beginning(the 6th byte)and read in file and write to ch.
    file.seekg(5L, ios::beg);
    file.get(ch);
    count << " Byte 5 from beginning is = " << ch << "\n\n";// it's 'f'.
//Move to the 10th byte from the end of the file and read the character there.
    file.seekg(-10L, ios::end);
    file.get(ch);
    count << " The 10th byte from the end is = " << ch << "\n\n";//it's 'q'.
//move to byte 3 from current position.(the 4th byte) and read the character there
    file.seekg(3L, ios::cur);
    file.get(ch);
    count << " Byte 3 from current = " << ch << "\n\n";// it's  'u'.
    file.close();
    return 0;
The first one is line 17 file.seekg(5L, ios::beg). So starting from byte 0 ('a'), go to byte 5 which is 'f'. That's easy.
Then line 21 file.seekg(-10L, ios::end). Looks like the end is 1byte after 'z', so byte( -1) is 'z'. so byte(-10) is 'q'. Still easy.
Then line 25 file.seekg(3L, ios::cur). The current position is 'q' after line 21. So learning from line 17, using 'q' as byte 0, so byte 3 should be 't'; WRONG, it is 'u'.
I type the program EXACTLY the same as in the book. I even copy the comments from the book telling how to count. for the life of me, I cannot figure out how to count this out.
I change line 25 to file.seekg(0, ios::cur) and ran the program, it show it's 'r'! How the hell it moves to 'r'?
Also when I change line 21 to file.seekg(0, ios::end), it become 'a'! It wrap around? I though it should be eof(0x00).
Please help. I've been stuck over a day already.
Thanks
Yes the cursor is at 'q' after line 21, but when you do file.get() in line 22 it moves it to 'r'...
... and then moving 3 more to the right moves to 'u'. You don't need to specify 3 as a long.
file.seekg(0, ios::cur) doesn't move it at all, it was at 'r' after file.get() in line 22.
I don't think it does wrap around, are you sure you typed ios::end correctly? It looks like it has instead moved the cursor 0 bytes from the beginning (which is the default base position if the second argument is missing).
If you want to know where the cursor is then you can use file.tellg(). Alternatively you can read the value at the cursor position without moving the cursor with file.peek() although this doesn't support reading into a char. Alternatively after get() you can use unget() to move the cursor back - but you should first check that the get() did not fail because of EOF.
@yungman, this and the other comments by pbuk are explanations of why you're seeing the behavior of your program.
Whichever character in a file is the next one to be read or written is determined by the position-in-file pointer, an internal mechanism.
After doing a read operation (i.e., with file.get()) or write operation (with file.put()), the position-in-file pointer is advanced to the next character, the next one to be read or written.
The idea is similar if you read or write multiple characters, with the position-in-file pointer being moved to the appropriate position.
You wrote this in post #1.
If you get a compile error, the program with the error won't run. In this case, VS will ask you if you want to run the last successful build. So "it seems to work" means that you were running a previous version that didn't have any build errors.
getline() and fstream::getline() (which is what is called by dataF.getline()) are completely different functions so there is no reason to expect them to work interchangeably. You will understand this better when you have moved on to classes.
... and then moving 3 more to the right moves to 'u'. You don't need to specify 3 as a long.file.seekg(0, ios::cur) doesn't move it at all, it was at 'r' after file.get() in line 22.I don't think it does wrap around, are you sure you typed ios::end correctly? It looks like it has instead moved the cursor 0 bytes from the beginning (which is the default base position if the second argument is missing).
Thanks so much for the explanation. I totally forgot the most basic thing about file read and write...that right after you read or write, it will point to the NEXT element to be written or read.!
Yes, that's the reason on the first line 17, when I change from 5 to 0, it gave me 'a', BECAUSE there is no file.get(ch) in front of it, so it never advance to the next element.
I don't think I type wrong on file.seekg(0, ios::end). I actually just change -10 to 0 in line 21 and run the program. I did that many times and it came up with 'a' every time. I just did rebuild solution and clean solution and run it again, still gives me 'a'. If I change line 21 to file.seekg(-1, ios::end) it will give me 'z'.
I never understand why they put 10L, -3L with the 'L'. The book actually described as long integer.
Textbook page showing a Random Access diagram of arrows between file positions, the seekp example file.seekp(20L, ios::beg), and Table 12-7 listing the ios::beg, ios::end and ios::cur mode flags.
Ha ha, Maybe now it's time for you to say I read it wrong!
Yes, I did try getting rid of the L and the program works the same. At least I know char is 1 byte, the string is only 26byte + eof = 27byte long. there is no way it is counted as long integer of 8 bytes each.
I can't wait to get to tellg and tellp after this.
Thanks so much for taking the time to explain this. Now I can move on.
Mark44 said:
You wrote this in post #1.If you get a compile error, the program with the error won't run. In this case, VS will ask you if you want to run the last successful build. So "it seems to work" means that you were running a previous version that didn't have any build errors.
I did not know that if I choose yes, it only display the last successful run. I will never do that again.
Thanks so much for helping me.
An offset of 0 from the end is the final byte of the file -- eof. To get the last valid character in the file, do this:
C++:
seekg(-1L, ios::end);
Here we have an offset of -1 (toward the beginning) from the end of the file.
BTW, the first argument to seekg() is of type streamoff, which in VS is typedef-ed as either __int64 or long. If you use an int value, it will be promoted to a long.
This wiki article about seekg, https://en.wikipedia.org/wiki/Seekg, has this to say.
Note: If you have previously got an end of file on the stream, seekg will not reset it but will return an error in many implementations. - use the clear() method to clear the end of file bit first.
I modified your program as shown below. The output is shown in the comments.
C++:
    file.seekg(-2L, ios::end);
    file.get(ch);
    count << " Next to last byte before EOF is = " << ch << "\n\n";//it's 'y'.
    //file.clear();      Not needed, since I didn't attempt to read beyond the last valid byte
    file.seekg(0L, ios::beg);
    file.get(ch);
    count << " Byte at beginning of file is = " << ch << "\n\n";// it's 'a'.
    file.get(ch);
    count << " Byte 3 from current = " << ch << "\n\n";// it's  'e'.
    file.close();
yungman said:
I did not know that if I choose yet, it only display the last successful run. I will never do that again.
Whether there is something new to run depends on whether you got a compiler error or a compiler warning. It may compile a new program if there are only warnings. When you ask for help, you should always tell us exactly what the error/warning message is. It makes a big difference and there is no reason to make us guess.
C++:
C++:
    file.get(ch);
    file.get(ch);
    file.get(ch);
    file.close();
Thanks
I don't quite get what is highlighted above, you mean I can specify what type like long int, int etc.? Can you give me a few examples like what you wrote examples of reinterpret_cast<float*>(&x).
I looked at wiki link, I have not learn istream&....
But I understand and know how to work like in the program you provided. I think I am good on this already. After I found my mistake of not counting of file.get() that advance the pointer, it all make sense.
I know file.seekg(-1, ios::end) is 'z', that's why I know the pointer was pointing to eof. But when I ran the program file.seekg(0, ios::end), it did give me 'a'. I rebuild and clear solution, and still it's 'a'.
Thanks a million. It's very helpful.
C++:
C++:
    file.get(ch);
    file.get(ch);
    file.get(ch);
    file.close();
Hi Mark
I just finished writing notes on chapter 12. I actually copy one part from you on reinterpret_cast that show converting to different datatype examples in that section. At this point, I am not trying to understand everything as a lot of them are in later chapters. Instead of try to understand like Casting and Classes at this point, I just write down how to use it and use the notes like a cheat sheet when writing programs. Like I never understand why programs in books always start with int main(){... return0;} until I studied chapter 6 functions, then I understand that main can be a function that can be called also and return an integer. If I kept trying to understand this in chapter 1, I will never get through the chapter. Like I still don't quite understand static_cast on int x=5; that int is datatype, x is an object and all that, all I know it is the same thing like fstream dataF or struct people{..}; that declare a datatype and given the internal members etc. If I get stuck on casting and all that now, I'll never move on. At this point, I just want to know the right way to use it within the context of the current chapter of the Gaddis book.
I have been working on my notes the last two days on the former chapters including page number to make sure I can copy the correct syntax when writing the codes and can refer back to the book if needed. Did find quite a few mistakes looking back.
Thanks
There's nothing really very complicated about casts. C and C++ are strongly typed, which means, for example, that the value being assigned to a variable should be of the same type as the variable, or that the actual arguments in a function call should be of the same type as the parameter types in the function declaration.
And you don't need to include the final return 0;. Apparently the standards committee decided to no long require it. The main() function defines the entry point for the program. It's called from the command prompt if you run your code outside of an IDE like VS. When the last line in main() executes, control returns back to the operating system running the command prompt window.
I saw a few mistakes in your cheat sheet. There might be a few more that I didn't catch.
yungman said:
*P652: fstream data type: fstream dataF; Object dataFile needs 2 arguments:
dataF.open(“filename”,File Access Flag);
dataF is an object, an instance of the fstream class, but it's the open() function that takes the 2 arguments. When you start studying classes in earnest, it's important to distinguish between a class (such as fstream) and its member functions. A class will typically have one or more member functions with the same name, the constructors for the class. If there are multiple constructors, they will have different sets of parameters. There will also be a destructor with almost the same name, except its name starts off with the ~ character.
yungman said:
*P666:
*Continuous read: Ar[50]; while(dataFile.eof()){ dataFile >> Ar; count Ar;} Will display data1 data2 data3.
Your logic is wrong here. Unless EOF has already been reached, the body of the while loop won't execute at all. The while header should be
while(!dataFile.eof()) ...
Your version is missing the ! (logical NOT) on the test expression.
yungman said:
*P678:reinterpret_cast<datatype>(value). <datatype> is data type to convert to, value is value you are
converting. In here <datatype> is char pointer.
There is nothing in what you wrote that says that <datatype> is char pointer.
When you use this cast with write(), then the first parameter has to be char*, but that's just one use of this cast, which can be used for other purposes.
yungman said:
*P678: .read and .write function expect the 1st argument be a pointer to a char. Must use reinterpret_cast
when writing and reading items of other data type to binary files.
1) the names of these functons are read() and write(), not .read and not .write.
2) reinterpret_cast is not required. The older style C cast can be used. The following works just fine.
C++:
dataFile1.write((char *)(&x), sizeof(x));
yungman said:
*The following are examples of using reinterpret_cast: int Ar[] = {1, 2, 3, 4, 5};
float *pFloat = reinterpret_cast<short*>(Ar) double *pDouble = reinterpret_cast<double*>(Ar)
Short *pShort = reinterpret_cast<short*>(Ar) char *pChar = reinterpret_cast<char*>(Ar)
Copy/paste error. The first one should be
float *pFloat = reinterpret_cast<float*>(Ar)
It could also be written as
float *pFloat = (float*)Ar ;
Again, casts are much less complicated than you seem to believe. All we're doing here is taking a value (Ar, presumably of type int[], which is more-or-less the same as int*), and telling the compiler to treatit as if it were the address of a float. That's all. There is no change at all to the bit pattern that makes up the address.
C++:
Thanks you so much to take the time reading it. I definitely print this out and read it very carefully.
Thanks
Hi Mark
I read through your response once, thank you for the information. I see dataF is the object, open(), write() and read() are the functions, not dataF.open() together is a function.
I deleted return 0; it works. But when I deleted int int in int main(), that got me an error. I put void main(), it works as I don't return anything. I guess I have to declare the datatype of the function main().
I am going to try float*pFloat = (float*)Ar tomorrow. Save a lot of typing! I have a bigger fish to fry right now that I don't quite get why I get one more read before eof().Thanks
Hi
I have one problem that I read the last file twice before the eof() terminate the the do-while(people.eof()) loop.
C++:
#include <iostream>
#include <fstream>
#include <string>
const int name_L = 51, addr_L = 51, phone_L = 14;
struct Info
    char name[name_L];
    //int age;
    //char address1[addr_L], address2[addr_L];
    //char phone[phone_L];
int main()
    int index = 0;
    Info person;
    char again;
    fstream people;
    people.open("people.dat", ios::out | ios::binary);
    do
        count << " Enter name: ";
        cin.getline(person.name, name_L);
    /*    count << " Age: "; cin >> person.age;
        cin.ignore();
        count << " Enter address line 1: ";
        cin.getline(person.address1, addr_L);
        count << " Enter address line 2: ";
        cin.getline(person.address2, addr_L);
        count << " Enter phone number: ";
        cin.getline(person.phone, phone_L);*/
        people.write(reinterpret_cast<char*>(&person), sizeof(person));
        count << " Do you want to enter another person? "; cin >> again;
        cin.ignore();
    } while (tolower(again) == 'y');
    people.close();
    people.open("people.dat", ios::in | ios::binary);
    do
        people.read(reinterpret_cast<char*>(&person), sizeof(person));
        count << " Name: " << person.name << "\n";
    /*    count << " Age: " << person.age << "\n";
        count << " Enter address line 1: " << person.address1 << "\n\n";
        count << " Enter address line 2: " << person.address2 << "\n\n";
        count << " Enter phone number: "<< person.phone << "\n\n";*/
        index++;
        count << " index = " << index << "    !people.eof() = " << !people.eof() << "\n\n";
    } while (!people.eof());
    people.close();
I put 3 out of 4 member components of the struct dataF person as comment to save typing. The struct only ask for name right now.
The first part is just writing as many person until I choose to end it. The second part of the program is to just print out all the person in the file. I enter 4 names, but when I read back, I read all 4 and repeat the last one before !people.eof()=0. As shown below:
Console output listing names entered (alan, john, paul, michael) with index values 1 to 5 and !people.eof() results, where the last record is michael repeated and eof() reads 0.
You see I input 4 names, but when read back, michael is repeated twice. I print out the !people.eof() and you can see it's only after reading michael again before !people.eof() = 0.
I am sure it's my mistake, I just cannot see it. I put the read() inside the loop, I should get eof() after reading michael the first time.
BTW, other than repeating the last one, the program works with all the rest of the members that I put as comments.
thanks
Yes. dataF is an object - an instance of the fstream class. open, write, and read are member functions of that class.
The dot notation is how you access a member of an object, whether the member is a data member or a function member. The dot notation is also how you access a member of a struct. The line above is calling the open function on the dataF object.
Yes, you have to declare a return type for main. VS allows you to write "void main(...)", but some other compilers don't allow this. "int main(...)" is the standard usage.
Regarding your program in post #18, I think this is what is happening. Assuming there are N names in the file, the program can read the Nth name with no problem. It is only when we attempt to read from the file again that a read error occurs. When the call to people.read() fails, the output statement displays the previous value.
Here's a loop that works correctly.
C++:
while(true)
        bool state = people.rdstate();
        if (state) break;    // If any of badbit, failbit, eofbit are set, state will be nonzero; i.e., true
        index++;
When the call to people.read(...) fails, people.eofbit and people.failbit are set, so people.rdstate() will return true.
Thanks
So in these cases here: int x; float y; char z; struct people;
fstream dataF
where int, float, char, struct, fstream and ALL datatype.
x, y, z, people and dataF are ALL Objects.
I still don't quite get where instance comes in. x, y, z are all Object of their respective datatype, then you said they are instance of of their datatype.
Thanks
@yungman, you really should test that the read was successful in your code before going on. It is a very bad habit to assume that a read was successful, especially a read of something expected to be in a certain format, and especially especially if the input was from a person.
I deleted that part when I post to shorten the program here, I always have that, It never have problem in this program.
C++:
while(true)
        index++;
Thanks for the reply
But if you look at post 18, I actually copied the cmd window that I display !people.eof() and show it did not change to False until reading the Michael the second time. I don't think that's caused by error in reading.
I since added line 41 to display the size of the structure sizeof(Info). The sizeof(Info) = 51 bytes. Then I find the total bytes using people.seekp(0, ios::end); people.tellp() = 153 for 3 names. So that proofs I enter the correct number of names in the file and the file stored the correct number of names.
C++:
#include <iostream>
#include <fstream>
#include <string>
struct Info
    char name[name_L];
    //int age;
void main()
    int index = 0;
    Info person;
    char again;
    fstream people;
    do
        cin.ignore();
        cin.ignore();
    count << " sizeof Info = " << sizeof(Info) << "       people.tellp() = " << people.tellp() << "\n\n";
    people.close();
    do
        index++;
    people.close();
Here is the copy of cmd window after running:
Console output of a C++ program: prompts to enter names, then sizeof Info = 51 and people.tellp() = 153, followed by lines reading each name, index and !people.eof() values.
too bad there are things I cannot display in debug-->window-->immediate
Visual Studio Immediate Window output: people.eof() reports function std::ios_base::eof has no address; sizeof(Info) is 51; people.tellp() reports std::basic_ostream::tellp has no address; sizeof(people) is 192.
I have to write that in the program on eof() and people.tellp(). I am having a ball with this debugger!
I deleted test of file.failure to shorten the program here. It never give me problem.
Thanks
A good habit is to read the input as an asci string and then scan the saved result to see if the format is correct. You can try scanning different ways with different formats, each time trapping any error, to determine what the user input was. That makes the reads much more robust and predictable and allows you to test the input.
The "standalone" getline() function that you used in line 13, reads into a std::string. The getline() function that is a member of the fstream class, that you used in line 14, reads into a C-string. They're two different functions, with the same purpose, but with different types of arguments.
I don't know why the people who wrote the C++ standard that introduced std::string didn't simply add an overloaded version of the fstream getline() member function that accepts a std::string.
C++ has occasional little quirks like that. Another example that used to really irritate me (fortunately no longer valid if you use a fairly recent version of C++):
When I taught C++, you had to use a C-string for the file name, when opening a file to create an fstream. If the file name was in a std::string, you had to use the c_str member function to convert it to a C-string:
Code:
ifstream myStream;
string myFile;
// put something into myFile, then...
myStream.open (myFile.c_str());
Beginning with C++11, you can simply do:
Code:
ifstream myStream;
string myFile;
myStream.open (myFile);
Hurrah! :woot:
This
and this
are mutually inconsistent.
You can't have written code that both tests for read errors and doesn't find a read error.
Vanadium 50 said:
Thisand this
I since added the if(!people){ count << " Failed"; return 0;} it's fine, still have the same problem.
C++:
//12.15A read structure from file created by 12.15
#include <iostream>
#include <fstream>
#include <string>
struct Info
    char name[name_L];
    //int age;
int main()
    int index = 0;
    Info person;
    char again;
    fstream people;
    if (!people)
        count << " Fail to open people";
        return 0;
    do
        cin.ignore();
        cin.ignore();
    people.close();
    if (!people)
        return 0;
    do
        index++;
    people.close();
The double read persists even though it pass the if(!people) fail test. That is NOT the issue. I did this many times before I remove the few lines. Read the result, it shows eof() is not true until reading the paul the second time.
Console output of a C++ program: user enters names alan, john and paul, then sizeof Info = 51 and people.tellp() = 153, followed by Name and index lines with !people.eof() values, ending with index = 4 and !people.eof() = 0.
No, it doesn't read "Michael" a second time, it prints it a second time because you don't test whether people.read() has succeeded before you go ahead and print the last value that you read into person. The reason people.read() fails on the 5th pass through the loop is because it attempts to read beyond the end of the file (and therefore the subsequent call to people.eof() returns true).
Oh, you've changed your test data. No, it doesn't read "Paul" a second time, it prints it a second time because you don't test whether people.read() has succeeded before you go ahead and print the last value that you read into person. The reason people.read() fails on the 4th pass through the loop is because it attempts to read beyond the end of the file (and therefore the subsequent call to people.eof() returns true).
You are right, I put if(!people) to exit and it only print michael once.
C++:
    do
        if (!people)
            return 0;
        index++;
BUT it's strange, if I replace if(!people.eof()), it failed the first time without printing anything!
I thought we should test for eof(), not fail. How do you know that?
I did not expect this can be a confusing issue, don't you read until eof()? In the example in the book, it only test if(!people) right after you open the file to make sure it open without problem. I thought from that onward, you only worry about eof().
Thanks
