Why involute gears have straight path of contact?
The path of contact for involute gears is a straight line due to the geometric properties of the involute tooth profile, which ensures that the line of action passes through the pitch point when the gears are properly meshed. This characteristic allows for variations in the distance between the pinion and driven gear without affecting the angular velocity ratio, making involute gears advantageous over cycloidal profiles. The pressure angle dynamics during engagement and disengagement also contribute to the operational efficiency and durability of involute gears compared to spur gears.
  • Understanding of involute gear profiles
  • Knowledge of gear meshing principles
  • Familiarity with pressure angle concepts in gear design
  • Basic mechanical engineering principles related to gear systems
  • Study the mathematical derivation of involute gear properties
  • Explore the differences between involute and cycloidal gear profiles
  • Learn about gear engagement dynamics and pressure angle effects
  • Investigate the applications of hypoid gears in automotive engineering
Mechanical engineers, gear design specialists, and students studying mechanical systems will benefit from this discussion, particularly those focused on gear performance and design optimization.
rahulpark
my lecturer keeps saying that path of contact of an involute gear is straight line but without the reason. i can't digest it as i can't find the reason for this behaviour. I'm trying my best to find the reason. Internet too can't find an answer. Books don't give a timeline of how it happens. Can anyone give a convincing answer?
you mean 'involute gear profile'.
Yes, it's involute gear profile
The usual way that lecturers today express advantages of involute profiles is by comparing them to the cycloidal gear tooth profile.Cost reasons apart,in an involute gear profile you can vary the distance between the pinion centre and driven gear centre without changing the angular velocity ratio(see law of gearing).This is very important for mechanical engineers as they don't have to worry about the tolerances so much.Big difference when compared to other profiles.
Spur or straight cut gears mess teeth along one line more quickly than spriral cut hypoid or involute gears. The pressure angle is max atthe start , goes to zero at mid rotation and returns to max pressure just prior to disengaement. This maximum pressure angle at the " tip " of the can cause high stress breakage with enough load. Spur gears are noisy and subject to higher shock due to more immediate contact upon engagement. The drive gear and driven gear must be located EXACTLY to permit proper meshing. Early Ford flatead engine automobiles used bevel (straight cut) ring and pinion differentials and would break teeth when horsepower was increased enough. Spiral cut gears engage at one POINT then gradually move this enagement point along the entire gear face yet maintain the same contact ANGLE PRESSURE from intial engagement to disengagement. These gears are smoother engaging and more quiet in operation and can handle more power load because of this gradually loading and holding the same pressure over the entire rotation. The drive and driven gear do not require as precise of a location as the spur gear and are less burdensome to assemble. Automobile manufacturers went to spiral bevel to handel the increased horsepower required for heavier vehciles and eventually settled on the hypoid design because they could lower the drive shaft and whole rear center of gravity.
Or something like that..
http://gearcutting.blogspot.com/2008/02/comparison-between-involute-and.html
But theory states distance between 2 involute gear profiles don't matter that much,take for example the 14.5 deg pressure angle set-ups.You could bring the gears close enough till the point of interference and bring them far apart enough keeping in mind the contact ratio never goes below 1.
I guess the velocity ratio stays constant in these distance limits no matter what.But,please clarify your point about distances between gears again.
  • · Replies 18 ·
46K
11K
17K
11K
