Why is angular momentum constant for central forces?
1 reply · 2K views
tryingtolearn1
Conceptual clarification between two questions
Angular momentum
I am confused with the following two questions:
1. A particle moves under the influence of a central force directed toward a fixed origin ##O##. Explain why the particle's angular momentum about ##O## is constant.
2. Consider a planet orbiting the fixed sun. Take the plane of the planet's orbit to be the ##xy## plane, with the sun at the origin, and label the planet's position by polar coordinates ##(r,\phi)##. Show that the planet's angular momentum has magnitude ##l = mr^2\omega## , where ##\omega =\dot{\phi} ## is the planet's angular velocity about the sun.
These two questions both have a particle that moves under the influence of a central force but conceptually why is the first question a constant but the second question is not a constant?
tryingtolearn1 said:
Homework Statement:: Conceptual clarification between two questions
Relevant Equations:: Angular momentum
The second equation involves the constant angular momentum ##l##. This tells you that, although ##r## and ##\dot \phi## separately are not constant, their product ##r^2 \dot \phi## must be constant.
The argument expressed in points 1 and 2 is fundamental to physics.
