Why is Cp larger than Cv?
zorro
This is a statement in my book 'The heat capacity at constant pressure Cp is generally larger than that at constant volume Cv because at constant pressure, a part of heat added to the substance may be used in work of expanding whereas at constant volume all the added heat produces a rise in temperature'. I did not understand these two things-
At constant pressure, how can heat added be used for expanding (since expanding leads to change in pressure).
At constant volume what if the added heat expands the gas?
If you heat something it usually inflates, to keep the pressure constant it has to expand.
In constant volume heated gas WANTS to expand - but as the volume is kept constant, it is impossible, so instead the pressure goes up.
what is the difference between expansion and inflation of gas?
None as far as I am concerned, sorry if it sounded as there is a difference.
