Undergrad Is the Delta Function a Scalar?
  • Thread starter Thread starter kent davidge
    Scalar
The delta function ##\delta^4(x-y)## is not a scalar but transforms in a specific way under Lorentz transformations. It is established that ##\int \delta^4(x-y) d^4 x = \int \delta^4(x'-y') d^4 x'## when integrated over all of ##\mathbb{R}^4##, confirming their equality. The transformation involves the Jacobian determinant, leading to the conclusion that the quantity ##\frac{1}{\sqrt{g}} \delta^{(4)}(x)## behaves as a scalar under coordinate transformations, where ##g## is the determinant of the metric. This insight is supported by Lovelock and Rund's work in "Tensors, Differential Forms, and Variational Principles".
  • Understanding of delta functions in four-dimensional space.
  • Familiarity with Lorentz transformations and their implications.
  • Knowledge of Jacobians and their role in coordinate transformations.
  • Basic concepts of differential geometry and metric determinants.
  • Study the properties of delta functions in the context of general relativity.
  • Explore the role of Jacobians in coordinate transformations in differential geometry.
  • Read Lovelock & Rund's "Tensors, Differential Forms, and Variational Principles" for deeper insights.
  • Investigate the implications of scalar and tensor fields in physics.
The discussion is beneficial for theoretical physicists, mathematicians specializing in differential geometry, and students studying general relativity and tensor calculus.
kent davidge
I read that ##\delta^4(x-y)## is invariant under Lorentz transformations. I was trying to show myself this, so I procceded as follows.
The following integrals are both equal to 1 ##\int \delta^4(x-y) d^4 x## and ##\int \delta^4 (x'-y') d^4x'## so I assume they are equal to one another, as long as we integrate them over all ##\mathbb R^4##. Now ##d^4 x = d^4 x'## because the Lorentz metric has ##\sqrt {| \eta |} = 1##. So I conclude that ## \delta^4(x-y) = \delta^4(x'-y') ##. Is this correct?
Pretty much correct.
A more detailed explanation follows. The delta function is what Lovelock and Run called a relative tensor. In essence the delta function must transform so that ##\int \delta^{(4)}\left(x\right) d^4 x## does not depend on coordinates. However, the "volume" form ##d^4 x## does depend on coordinates. If we switch coordinates using a map ##\phi: x\to\bar{x}##, then ##\int_V \dots d^4 x = \int_\bar{V} \dots \frac{\partial\left(x\right)}{\partial \left(\bar{x}\right)} d^4 \bar{x}##, where ## \frac{\partial\left(x\right)}{\partial \left(\bar{x}\right)}## is the Jacobian.
It follows that:
## \frac{\partial\left(x\right)}{\partial \left(\bar{x}\right)} \delta^{(4)}\left(x(\bar{x})\right) = \delta^{(4)}\left(\bar{x}\right)##
to counteract the scaling of the volume element. With some work (Lovelock & Rund, "Tensors, Differential forms ...", Chap 4) you can show that ##\frac{\partial\left(\bar{x}\right)}{\partial \left(x\right)}=\sqrt{\frac{g}{\bar{g}}}##, where ##g## is the determinant of the metric in the initial coordinate system.
Finally, you can conclude that whilst delta function is not a scalar, the following quantity:
##\frac{1}{\sqrt{g}} \delta^{(4)}\left(x\right) = \frac{1}{\sqrt{\bar{g}}} \delta^{(4)}\left(\bar{x}\right)##
is. It does not come into play for basic Lorentzian boosts, because, as you noted ##\sqrt{g}=1## at all times.
  • Love
Likes kent davidge
  • · Replies 123 ·
